Borris The Blade Posted May 30, 2013 Report Posted May 30, 2013 Found one in Pittsburgh not sure how far that is from you http://pittsburgh.craigslist.org/ele/3788829647.html It's like rubbing your wiener up against a sheep.
Omega5002 Posted May 30, 2013 Report Posted May 30, 2013 Think with a big magnet, 3.5 voice coil, and much better soft parts than Kicker(and not being square), should handle 2.5k on each no problem 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
slc123 Posted May 31, 2013 Report Posted May 31, 2013 Man lookin good!! That's exactly where I'm at in my rebuild. Upgrading/adding more 1/0 to my electrical, had to strip out a little of the old stuff while I was adding more. Isn't it so much fun!! Anyhow yours definatly is lookin clean, I think those are the exact same terminals we use at work, had to borrow a few for my truck lol! I know what you mean by the solder sucking it right up those things work good! I have to say out of all the 1/0 terminals I've use probably 5-6 diff brands, the Rockford's are my fave! They just look awesome and they solder great, BUT they are too damn expensive! Especially when you can get these for the price they are, I mean it's a no brainer if you are buying your own stuff these are more realistic for a build with a shiz ton of cables. If you don't mind me asking where did you get that cable wrapping? I use the plastic conduit but I'm thinking I may have to do some of that stuff if it's reasonable...which sucks because I'm almost done with the cabling part but oh well, easier the second go round right lol! Keep it up bro! My 03' sierra crew cab Here build in progress
DroppedSdime Posted May 31, 2013 Report Posted May 31, 2013 So I had to lay it out, then take it back out, cut it, then re install both runs. I am using the rear air ducts as wire loom! It just works out better, I don't have room for three runs to all go along the side. Here are the two straight runs cut to length Time to solder some ring terminals. These terminals from Crimp Supply are the best I have ever used, period. The solder just wants to stick to it, and you don't even have to use flux. I then added tech-flex, for extra protection, and cause it just looks so damn good! One down, one to go! So next is to get them in the car. Also, notice the hood latch cable.. reinstalled and working perfectly! One goes straight to the fuse box, while these two branch off this way. Go thru here Up to here And end up here More pics on the way... Are you happy with the sky high wire? I was thinking of ordering a couple spools for myself.. SPL Audio 18, 5.5cb ft tuned to 34 hzAB 150.1 @1400 rms wired to 1OhmPPI A26.5'sKenwood HU
armykyle1 Posted May 31, 2013 Report Posted May 31, 2013 Looking really good. TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
Purplehaze Posted May 31, 2013 Author Report Posted May 31, 2013 Wow nice job so far really liking the progress and the custom subs man! Keep it up! Thank you! Nice job....Goodluck finding the rest....keep up the great work Thanks man! Love it man! What baskets are those Think he said Soundstream XXX baskets The white one is a Soundstream XXX 15, the yellow ones are TC Sounds. They are the exact same thing from what PSi told me. Man you've come such a long way since the first build. Everything is looking so nice and so clean. Very meticulous about everything right down to the last detail. I am loving what you're doing and where this is going. Keep it up man. Very excited for more updates! Lovin it! I hope you can find the last motor cause those would be killer built the way you showed in that picture, your favorite one. Thanks bro! Yeah I'm excited about this now more than ever! I will most likely do mine like the white one, it is just sic! Gold xxx baskets? They were painted, and actually I believe those are TC baskets. But I was told they are exactly the same thing. Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
Purplehaze Posted May 31, 2013 Author Report Posted May 31, 2013 So how much power will these subs take Dave said it depends on what I want: If they are built for music the RMS w be ~2000 watts. Of course burp subs could take more, but mine will be built for music. Found one in Pittsburgh not sure how far that is from you http://pittsburgh.craigslist.org/ele/3788829647.html Sweet! Thank you very much! I sent him an email, hopefully I will only need two after this! Think with a big magnet, 3.5 voice coil, and much better soft parts than Kicker(and not being square), should handle 2.5k on each no problem That's what I thought too, but when I spoke with dave from PSi, he explained it like this. "We can only rate the RMS power handling of these at about 2000 watts rms. the sub uses a 3.5" coil, but it has to be a slim 4 layer 3.5" coil… not a monster!" To get them up to 2500 rms, they gotta be built for tones, w/ a bunch of spiders, and they sound like ass on music, is basically what I was told. Man lookin good!! That's exactly where I'm at in my rebuild. Upgrading/adding more 1/0 to my electrical, had to strip out a little of the old stuff while I was adding more. Isn't it so much fun!! Anyhow yours definatly is lookin clean, I think those are the exact same terminals we use at work, had to borrow a few for my truck lol! I know what you mean by the solder sucking it right up those things work good! I have to say out of all the 1/0 terminals I've use probably 5-6 diff brands, the Rockford's are my fave! They just look awesome and they solder great, BUT they are too damn expensive! Especially when you can get these for the price they are, I mean it's a no brainer if you are buying your own stuff these are more realistic for a build with a shiz ton of cables. If you don't mind me asking where did you get that cable wrapping? I use the plastic conduit but I'm thinking I may have to do some of that stuff if it's reasonable...which sucks because I'm almost done with the cabling part but oh well, easier the second go round right lol! Keep it up bro! Thanks man! That is called Tech-flex, I got mine from eBay. But watch, they have two different kinds, one is flame retardant and one is not. It's good stuff for sure, I love it! Plus I just love the way it looks! Are you happy with the sky high wire? I was thinking of ordering a couple spools for myself.. Man I am MORE than happy with the Sky High cable. Best cable for the money easily IMO. I just got some more actually! And I would recommend it to anyone for sure! Looking really good. Also I have another small update on the way! Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
Purplehaze Posted May 31, 2013 Author Report Posted May 31, 2013 Okay so I got a little bit done yest. Finished up the Big 3, check it out!Alt. positive and ground. to battery positive and neg.This is the tech-flex I use. The one w/ the white stripes is flame retardant - for under hood wires.Soldering some terminals. Again, these terminals are the shit!!!Here are both wires after tech-flex, added some blue hs to the positive also.Then, might as well put them together outside the car..First some zipties, then more tech-flexInstalled to the alt. Big three is now complete! Now I just gotta run my neg. front to back runs, which will go under the car, and that will be it for running cable!Also pay no attn to this batt, it is only there temporarily, till I get the new bussbars and batt. hold down pieces built. Which I think I will do next.Stay tuned! More ahead! And thanks for lookin'! Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
