Question
Cboeger
Never used them before, they look a little on the cheap side but will work. You just hope they dont effect sound quality due to materials useed to make them. Just depends on system set up and what your trying to acheive.
I use those on any speaker that does not have a push terminal. They work very well. Put the wire in, solder, connect to speaker, done.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
well i would take his word for it over mine. I bought gold terminal connects on my build but if he says there good. Use them!
Do you have any other setups you use when you try to use speaker harnesses and the car speaker terminals are too big for the harness connection?
Could you post some pics of what you mean? I'm not really following what you are saying.
Well basically you got the wiring harness right? its suppose to connect to the factory harness so you dont have to cut factory wires and solder them with speaker wires and run them to your new speakers. the wiring harness connects to factory harness and has wires that are suppose to conenct to your speaker terminals. well the speaker terminals dont fit those wires adapters at end because its too large. so your suppose to use the things i linked you too.
Still not following. Pics would help greatly. All the harnesses I've dealt with just have bare wires on the end and you either solder&heat shrink, or use butt connectors to join them.
Like this
tthose will work fine you can solder or crimp them it wont make a noticable difference in sound quality unless you are trying to build a nationally ranked sq car
Like this
was tlaking about speaker harnesses not stereo harnesses ;p
  • Who's Online   0 Members, 0 Anonymous, 1424 Guests (See full list)
