1loudhoe Posted May 16, 2013 Report Posted May 16, 2013 ive used this resin before and will be using it for my door in 2 weekshttp://www.homedepot.com/p/t/202077791?storeId=10051&langId=-1&catalogId=10053&productId=202077791&R=202077791#.UZUvCrWsiSo
Rell Posted May 17, 2013 Report Posted May 17, 2013 Buy good resin the first time an save yourself the headache. Better thinner resin wets out much easier and you end up using less resin. Bondo/3M resin at any hardware/auto store is the same shit. It will have wax in it so you must sand between layers. If you let a layer cure, then you need to sand it then apply the next layer of chop mat if you wish to contiune. So strech fleece Soak with crappy resin and let cure Sand the fleece Then add chop mat Ideally you want a quality laminating resin. No need to sand between layers.
shogen Posted May 17, 2013 Report Posted May 17, 2013 Buy good resin the first time an save yourself the headache. Better thinner resin wets out much easier and you end up using less resin. Bondo/3M resin at any hardware/auto store is the same shit. It will have wax in it so you must sand between layers. If you let a layer cure, then you need to sand it then apply the next layer of chop mat if you wish to contiune. So strech fleece Soak with crappy resin and let cure Sand the fleece Then add chop mat Ideally you want a quality laminating resin. No need to sand between layers. so with the 435 resin from uscomposites can be laid on without "real" sanding between layers? just curious .. also can someone with more knowledge give a quick break down of process.... that fiberglass site everyone links no longer lets people sign-up anymore Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Bump4life Posted May 17, 2013 Author Report Posted May 17, 2013 i used the 3m stuff and had no issues with it. then again i leathered over it. for my first real go at a good pod i was happy and they were very strong!! and glassed inside of my box too and matted. no issues!! Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
XmaximuS Posted June 28, 2013 Report Posted June 28, 2013 pics? X MY BUILD LOG>>>> NAH I BETTER NOT..
Kyblack76 Posted June 28, 2013 Report Posted June 28, 2013 Ill just add what i rolled with.. I waited, and ordered from US COMP. I saved a 3rd the money. and, its better product. My 2 pennies.... just order online. Unless you need it right now.. and even then.. id say wait.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
bighossf150 Posted June 29, 2013 Report Posted June 29, 2013 Ill just add what i rolled with.. I waited, and ordered from US COMP. I saved a 3rd the money. and, its better product. My 2 pennies.... just order online. Unless you need it right now.. and even then.. id say wait.. this right here, all is use is us composites 435 Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Bump4life Posted July 2, 2013 Author Report Posted July 2, 2013 pics? X look at my build log Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
