Steve would you sign my VM1 I'm Matthew Reeves.....
If not I understand. Thanks for making a quality product.
One of the VM I'm sending you doesn't work and the other
one. POS worked sooo slooow. BTW nice catch on the fly lulz
  • 1 year later...
Hmmm... very tempting offer... I love how the VM1 works... the movement is a lot more "fluid" than the digital meter.
Question is: Can I get the dimensions of the device so I can see if I can make it work. I have a great spot to put one, but I want to make sure I can actually fit it in place first.
Go here and see product description
http://www.wccaraudio.com/smd-products/smd-meters/volt-meters/smd-12v-volt-meter-smd-vm-1.html
I purchased this one brand new. Does this apply to a discount if I send you this one Steve? It's still in new packaging. Thanks in advance!
http://www.ebay.com/itm/131140670838?_trksid=p2060353.m1438.I2649&ssPageName=STRK%3AMEBIDX%3AIT
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
  • 1 month later...
Is there a way to dim the display on the VM-1? That is one of the issues I have with the cheap One Hung Lo brand meters, the display is too bright for night use.
no.
It's only one LED. It isn't too bright.
The OM-1 can get a little bright though depending on how loud your system is being played....it has several LED's. The vm-1, tm-1 shouldn't be a problem for most.
Follow my Tweet (Twitter)
  • Who's Online   0 Members, 0 Anonymous, 515 Guests (See full list)
