help designing a box
I actually like the way that port is rounded over and coming up through the deck. You don't like the way it sounds?
before it was sealed, i loved it!.
but was always told to seal it off to get it louder and it sounds like it completly changed everything.
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
yes. i sealed it before the port. towards the cab. so its from port to trunk thats open
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
I would have made a custom rear deck cover so that any chance of a leak was excluded from there (specially), you have to completely be air tight everywhere or not seal off at all.
hmmm i'll seal off around the rear deck and see if that helps any.
i'll let you know
thanks joe x
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
So everything is sealed off? If so port and sub forward. Unseal it and do port and sub back!
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
they way you have it is fine but something else isnt adding up either your port isnt right or your box and port isnt right but you need to seal the port area off to see the effects
thats what i plan on doing this weekend ric006
its port up ( 3 1/2 inchs of the port is outside of the box) and subs foward toward front. sealed off on the sides and on top of the box. from behind the seal off on top is open.
here is a pic to show the port seal off setup
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
That is not enough since all around the port there is a hole to the trunk airspace and therefore is not sealed, I would make a rear deck cover that fits like a glove the port and then use a sealant all around it.
  • Who's Online   0 Members, 0 Anonymous, 1832 Guests (See full list)
