Sky High Car Audio
SkyHighCarAudio Cable Order Thread(Updated 7/5/13)
CJ18
  • 3 months later...
Dont have enough time to read through all this to answer my questions lol
OFC is def more expensive than CCA wire. Im not quite sure what the difference is but would it be advisable to buy the OFC over the CCA? Im not doing anything crazy here, just a Fi Q on ~1700ish
Currently:
2015 Evo X WW
Forgestar F14 18s --Rally Armour Mudflaps
ETS 3.5" FMIC, CAI, Open Dump DownPipe, Test Pipe, Ultimate Racing Catback, BLEVINS TUNE, Fortune Auto 500 Coilovers
Build:
Crescendo Mezzos x2
Crescendo 800.4, 1500.1
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Sky High Audio Wiring
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
3.8L S/C-few modsWheels: Ruff Racing 280 19x8.5 Sub: Fully Loaded
12" Fi BTL Amps: Autotek MM3000.1d Sundown SAX-100.4HU/Tweets/mids:
Alpine D310 + H701, TBI HDSS tweets, Mpyr audio 65m x4extra sheit:
knukonceptz 0, 4, rcas, speaker wire EA 200amp alt HC 2400
TEAM DEADLY HERTZ!!
Financial Consultant- Charles Schwab
1/0 CCA would be fine for that. But in the long run you're better off with OFC because no matter how much you say you won't want to right now, one day you want more power. It's inevitable. Bite the bullet, get OFC, and later on down the road you'll say to yourself how happy you are you don't have to buy more wire.
Im just gauging how much i need and what exactly i need? Wiring is way not my forte. Ill have Xs in the trunk, where the stock batt was. Im guessing there is no real reason to run wiring from under the hood to the back? Only reason i can guess is for the alt.
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
Ofc or none. Is my option. Specially if you have bigger then a stock alt.
not planning on upgrading the alt any time soon, really just want to get this shit started. I have all my equipment but box, sub, and wiring.
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
If you can swing it get the ofc, it will be worth it in the long run.
now how much of it do i need. again stock batt is in the trunk
Currently:
2015 Evo X WW
Build:
Crescendo Mezzos x2
Loaded Fi Q12
Second Skin Pro
XS D5100
RF 360.2
Need: ALTERNATOR!
PREVIOUS
1999 Grand Prix GTX
TEAM DEADLY HERTZ!!
Yes, either a run from the alt to the back battery or from front battery to back battery. Unless you want to drain the back battery and put low voltage to your amps. No bueno. I'd go with a 50ft spool. You'd have enough for a run front to back for charging the back battery, enough for big three, and enough for back battery ground, and amplifier power/grounds, and still have 15+ft to spare in case you ever need it for whatever reason. And don't forget to fuse within 1ft of each battery connection.
Edit: even with stock battery in the trunk you should still run from alt to rear battery at least. stock wiring isn't chosen for full alt output in my opinion, which is a possibility even with a 1700w amp.
I had cca in the Honda forever. It lasts about 15mo before it me,to under the hood. In 4 years over replaced t it 3times and cost me a battery. All closed ring terminals. System is small. Just a JL 1000/1
  • Who's Online   0 Members, 0 Anonymous, 5511 Guests (See full list)
