ncc74656 Posted May 17, 2013 Author Report Posted May 17, 2013 o scope: http://minneapolis.craigslist.org/hnp/tls/3776367589.html nothing, gutted
ToNasty Posted May 18, 2013 Report Posted May 18, 2013 that thing is probably older than you ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
ncc74656 Posted May 18, 2013 Author Report Posted May 18, 2013 lmao yes it is. i like the idea of the old tech tho, id love to have an old o scope that still works to set on my work bench. im sure id find more uses for it. nothing, gutted
ncc74656 Posted May 18, 2013 Author Report Posted May 18, 2013 i just sent an email off, im going to buy this set if i confirm it works. looks like a killer deal!! http://minneapolis.craigslist.org/hnp/atq/3810750992.html so to test it i connect the ocope leads to the amp terminals while the sub is also running to give the amp the proper load, or should i simulate a 2ohm load and leave the sub off? nothing, gutted
kickass audio Posted May 18, 2013 Report Posted May 18, 2013 dude don't get that old thing. you want a newer one with a faster refresh rate (mHz or gHz) those are super old and slow at responding to little changes in the signal. Just do yourself a favor and get the dd-1 and cc-1. As for getting a headunit with more eq bands, that doesnt mean shit for tuning the x-over. As I found out the x-over on my headunit and my 3sixty.2 are off by quite a bit. Also with any eq you should have them set so the response from your speakers is flat. You don't do what most morons do and boost the living fuck out of lower frequencies "because it sounds good", you want to turn them up or down to have a flat response for your speakers to play. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
ncc74656 Posted May 18, 2013 Author Report Posted May 18, 2013 ahh, so the oscope package up there might be to slow to respond and thus give me poor readings. ill have to look into it more, id just really prefer to have a sine wave graph. i currently have a decently flat eq but my issue is my tweets are still getting bass and i need to drop the bass in my eq to stop them from distorting. i just cant seem to get this system crystal clear. i am rebuilding my wiring and fuse blocks and adding a bi-amp setup to try and combat this issue, using a MTX for tweets, eclipse for mids, and kicker for sub. i hope that helps. nothing, gutted
Guest Posted May 18, 2013 Report Posted May 18, 2013 lol i wonder how much that thing will cost to repair once it goes out. cc-1 for crossovers. dd-1 for distortion. both will fix your issues, assuming the user can operate them properly. red lights > having to squint your eyes and zoom/focus/adjust the line on the oscope screen to see distortion. distortion =/= clipping. clipping is easy to spot on a scope since the waves square off at the peaks. distortion isnt as easy to spot unless you have one of those fancy digital scopes that cost more than some peoples cars.
kickass audio Posted May 18, 2013 Report Posted May 18, 2013 You need a good crossover network for that to get fixed. you are doing nothing to fix it. Bi amping helps but most amps don't have an x-over network to get up in the 2.5kHz range where tweeters should be set for high pass. And its not a sine wave graph. Its just an normal o-scope. I have the TPI-440 PLUS o-scope and I use that all the time for all the electrical problems I work on and fix. If you do a lot of fucking around with electrical get the o-scope like that or their next step up model with a faster data rate to view glitches better. If you just plan to tune your system and a few friends just get the dd-1 and cc-1 combo pack. Trust me, it is sooo worth the money. I love that I bought both. Even though I have only used the dd-1 and cc-1 in my truck and a friends truck it is still worth every penny for how easy and great it is to use. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
kickass audio Posted May 18, 2013 Report Posted May 18, 2013 Kranny. the clipping isnt always that easy to detect with the scope. My dd-1 went off 1 volume level before my o-scope detected the wave getting flattened out. I even zoomed in on the peak and valley of the wave to see it better but the dd-1 won every time. And setting the x-overs with the old voltage method is horribly inaccurate. Don't do it. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Emmet Posted May 18, 2013 Report Posted May 18, 2013 i just sent an email off, im going to buy this set if i confirm it works. looks like a killer deal!! http://minneapolis.craigslist.org/hnp/atq/3810750992.html so to test it i connect the ocope leads to the amp terminals while the sub is also running to give the amp the proper load, or should i simulate a 2ohm load and leave the sub off? A killer deal? It's a cathode tube o-scope. Pretty much the earliest made before they had the electronics invented to display the wave. It's a museum piece. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
