Sergeant_Skyrim Posted May 23, 2013 Report Posted May 23, 2013 Finally getting around to upgrading mids and highs (never done anything mids/highs related before) so now I'm at the stage of purchasing them so I just wanna double check and make sure I'm getting this all correct... C1100.4 does 300x4 at 2 ohms and 180x4 at 4 ohms. So I can hook up 2 4-ohm PWX 6.5s at a 2-ohm load on one channel, 2 on another channel, and then have 2 more channels to temporarily run both of my D2 Zcons at 4-ohms for ~180 watts RMS per sub right? Drew a sketchup here: What I'm basically asking: 1. I can assume the PWX 6.5s are single voice coil? So I'd want the 4ohm models, right? 2. I can run each channel at a different ohm load? I've never had experience with this, only used monoblocks so far. 3. When I get a pair of FT1 Supertweets in the future (80RMS a piece) I should go for the 8-ohm model right? Then wire both down to 4 on a single channel? 4. Everything else here looks right? Pretty excited to get this build finally rolling, been in dire need of mids and highs for a while lol Build in progress
Sergeant_Skyrim Posted May 23, 2013 Author Report Posted May 23, 2013 Also to note: Wanting to hop on this ASAP considering the 6.5s just got in. Probably looking to order today or tomorrow, today is more likely if I get good feedback on this soon Build in progress
BobbyG2 Posted May 23, 2013 Report Posted May 23, 2013 Two ft1s per side would be ridiculously bright with only two pwxs per side. I'd go with one ft1 per two pwxs. It wouldn't matter too terribly which ohm load you go with cause you could always turn the gain down if 4 ohms is too much. *New vehicle and system coming soon.*
BobbyG2 Posted May 23, 2013 Report Posted May 23, 2013 I'd also keep the ft1s on separate channels for the stereo effect *New vehicle and system coming soon.*
Sergeant_Skyrim Posted May 23, 2013 Author Report Posted May 23, 2013 Oh no, I meant just 1 pair of FT1s haha. 4 Total PWX 6.5s for now, with 2 total FT1s in the future. And I'm in the process of walling off my Cavalier within the next month or so. Both 12" Zcons will be behind the front 2 seats with all of the 6.5s and tweets in the top area of the wall with a possible 4 more 6.5s up there in the future depending on how loud this all gets Build in progress
fox_racin4 Posted May 23, 2013 Report Posted May 23, 2013 A wall for 2 12s? If i understand your post, Yes it will work 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Sergeant_Skyrim Posted May 24, 2013 Author Report Posted May 24, 2013 A wall for 2 12s? If i understand your post, Yes it will work Yeah, I'm working in a 2003 Chevy Cavalier where it's damn near impossible to do anything in it room-wise. Box for both Zcons wouldn't fit in the trunk without having to build it inside the trunk, but then I've got the extra battery(s) and amp (DC 9k coming soon) to fit somewhere in the car as well. In addition to adding 2 more 12s in the future all wired down to 1 ohm...figured why not! Big plans for the future assuming I haven't changed my mind by then haha Build in progress
RooTxBeeR Posted May 24, 2013 Report Posted May 24, 2013 Want to see that when it's finished. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Swordlordboy1234 Posted May 24, 2013 Report Posted May 24, 2013 Sounds like some good stuff. Only part I'm not sure about is the huge ass freakin wall for 2 12's without having to completely rebuild the wall for 2 more 12's My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
fox_racin4 Posted May 24, 2013 Report Posted May 24, 2013 You can easily fit a box for 2 12s into your trunk. Go from the front, threw where rear seats go, you may need to do some trimming but you can easilly fot 6 cubes. I fit 7.5 cubes into a 1995 grandam And a little bigger into a 1994 cavalier 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
