Need help with box design
i just picked up some aa havoc 12s that i'm going to throw in my 2001 monte carlo. its going to be my first box build but i need some help with the design. i feel like the re box design site isn't too accurate and do not know how to use others so all help/designs will help.
here's what i had measured from my trunk to work with, 34 inches wide, 15 inches tall, and 21 inches deep, but was kinda thinking i should double baffle the front and back? any help would be great, thanks!
Here is a suggestion, please read notes below:
Enclosure Specifications:
Fb = 34 Hz
Vb = 2.2 ft^3
External Height = 14 in
External Width = 27 in
External Depth = 18 in
Port Width = 2 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 27 x 14
Left & Right Sides = 15 3/4 x 12 1/2
Top & Bottom = 27 x 15 3/4
L Port Internal Assembly Parts:
Front to Back = 13 1/4 x 12 1/2
Extension = 9 3/4 x 12 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 2 1/2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
rendered the same box for you. have free time to do so. weight is ~54 lbs
enjoy
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Thank you joe. I hope you don't mind me doing tho. I might aswell use the program while I have it. Puts it into perspective of how it should look when finished. Ok no more thread jack.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
No of course I don't mind it's great work but if you do enough of them you will see why I usually use generic ones.
Lol ok. Just gives a little better idea of what it should look like. Thats y I like doing them.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • 1 year later...
  • Who's Online   0 Members, 0 Anonymous, 9043 Guests (See full list)
