soundstream xxx15K
heightzbest562
i came across this amp and heard its the same ass the xxx15k , im thinking of running this amp at around 13-14volt just looking to get about 5000rms at .5 opinions ?
http://www.sonicelectronix.com/item_43839_Precision-Power-PDX-10K.html
  • Monoblock Class D PDX Series Car Amplifier
  • 16 volt RMS Power Rating:
    • 4 ohms: 3,700 watts x 1 chan.
    • 2 ohms: 6,100 watts x 1 chan.
    • 1 ohm: 6,100 watts x 1 chan.
    • 0.5 ohm: 10,000 watts x 1 chan.
  • Protection sensing circuit for maximum power
  • Pulse Width Modulated MOSFET power supply
  • Wired remote bass level control included
  • LED power (green) and protect (red) indicators
  • Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
  • Soft start turn-on
  • Mono channel operation
  • 3-way protection circuitry (thermal, overload, and speaker short protection)
  • Dual speaker terminals simplify the hookup of multiple speakers
  • Heavy duty aluminum alloy heat-sink
  • Nickel-plated RCA level inputs
  • Nickel-plated screw terminals
  • Input sensitivity:
    • Low level: 125mV-5V
  • Variable low-pass filter (35-250 Hz, 24 dB/octave)
  • Variable Subsonic filter (15-50 Hz)
  • Damping factor: >1000
  • CEA-2006 compliant amplifier
  • Frequency response: 15-150 Hz
  • 0 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
  • Dimensions: 12-5/8"W x 23-1/4"L x 2-3/4"H
  • Authorized Internet Dealer
  • 1-year Manufacturer's Warranty
Notice the 16 volt rating expect far less than that in a 12 volt c a r.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Not the same xxx has 6 inputs
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
you think it would still be powerful enough to power 2 xl m2 at .5? because every other amo that does 4-5Kw is about the same price as this
If you're dropping serious cash like that, it's a better idea to get an amp you know will power your subs well. A DC 5k would be my first recommendation.
Go with something that you know is proven and not something you are having to ask around and hope you get what you need.
I know old school Precision Power stuff was legit, not sure about the new. Also something that would turn me off is the price. a true 10k amp at .5 ohm for $1200? I think alot of people would be jumping on this if it were true.
amen!!!
mtx rfl 152 x 4 15 inch
mtx 9500 x 2 12 inch
mtx 5500 10 inch x 2
b2 audio m1s mark 2
here for the love off the game - not politics
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
