sundownford Posted June 3, 2013 Report Posted June 3, 2013 Hi, i am new to the site and I just recently got a sundown zv3 12 and have a rf t1500bdcp amp pushing it. It's wired at one ohm right now and I am getting a pretty bad voltage drop not even at full tilt. I turned it down when i seen 11.8. I need some advice, right now I have a stock alternator in my truck which is a 2011 f-150. I have done the big three and that's about it. I am wondering if i should do a second battery or change out the stock battery under the hood? Give me your input. Thanks
bighossf150 Posted June 3, 2013 Report Posted June 3, 2013 xs d6500 under the hood and a 250ish amp alt if thats not enough. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
OrzechNJ Posted June 3, 2013 Report Posted June 3, 2013 I would replace the front batt first.. and see what happens for 1500rms it would be good but not necessary to get a HO alt do u have big 3 in 0 gauge? Welcome ;] sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
sundownford Posted June 3, 2013 Author Report Posted June 3, 2013 Yes the big three is 0gauge. Well the 1500 isn't all i have I have about 300 watts for my mids and high. I really want to stay away from an alternator, because it is a huge pain to get to (bottom of the engine near the oil pan lol)
justin0943 Posted June 3, 2013 Report Posted June 3, 2013 differently up the battery and alt I have the older t1000bd amp before the big 3 9v after 11v stable so you will see difference their.Thats with everything stock 90amp alt to and battery. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
sundownford Posted June 3, 2013 Author Report Posted June 3, 2013 Okay, so i just found out the stock alternator on my truck is 155amps. I think I might be able to get away with just a second battery
justin0943 Posted June 3, 2013 Report Posted June 3, 2013 that 155amp alt not enough, for my t1000bd I need a 170 or 200amp alt with a good battery under the hood if your not going to up the alt your going to need 2-3 extra battery 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
slowfkncar Posted June 3, 2013 Report Posted June 3, 2013 Replace your under hood battery with a big one,make sure your battery has solid and big enough grounds to support the chassis ground in the rear (or just do the big 3)
slowfkncar Posted June 3, 2013 Report Posted June 3, 2013 Just remember,to many batteries on your stock alt may not fully charge while slammin your sounds driving.
