LiL PiNoY Posted June 6, 2013 Report Posted June 6, 2013 I know i wired it correctly so any ideas? ascendant audio hacoc 12 dual 2 its supposed to be wired to 4 ohms, 2 for each coil but get a reading of 3
BobbyG2 Posted June 6, 2013 Report Posted June 6, 2013 1.5 Ohms DC resistance is 2 Ohms nominal. Your sub will have a higher resistance while playing that's why they design it to be a little lower when not under power. *New vehicle and system coming soon.*
CstrokerV Posted June 6, 2013 Report Posted June 6, 2013 measure each coil separate see what they say my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
CstrokerV Posted June 6, 2013 Report Posted June 6, 2013 1.5 Ohms DC resistance is 2 Ohms nominal. Your sub will have a higher resistance while playing that's why they design it to be a little lower when not under power. if he got the dual 2 it shouldnt read 3 ohms with a d.m.m... even the site shows re at 3.7 in sereis. and the dual ones on my friends read 1 each coil with a d.m.m my dc lvl3 dual 2 read 2 ohms op did you buy it used? my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
bkolfo4 Posted June 6, 2013 Report Posted June 6, 2013 3 ohms is fine. You are measuring the DC resistance of the coil wire. Impedance is the AC resistance of the coil when AC is applied. Nothing wrong with it. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
LiL PiNoY Posted June 6, 2013 Author Report Posted June 6, 2013 Ok thanks Brian didn't want to disturb you with another question. @CstrokerV no brand new from bkolfo4.
RobertR Posted June 6, 2013 Report Posted June 6, 2013 Dont forget about DMM bias. Ive seen some that would read .5 ohm when you touch the leads together. BMW 325i Kenwood KVT-647DVD re xxx components re 6.5 FR's 2 RE XXX 12's 2 US amps MD3D's 2 batcap 4k's
