CleanSierra Posted June 8, 2013 Report Posted June 8, 2013 pretty sure the acetone is not allowing the resin to cure. Acetone eats ca glue up, makes many types of plastics, rubber, vinyls gooey, can strip paint. So I could only imagine what it does to uncured resin. After all the stuff is what fingernail polish remover is made mostly off. Acetone is way different from styrene from what I recall. Yea it is different. Maybe I wont use anymore of it. Still seems like a weak reaction even with plain resin. Last year the shit was turning my brush into a brick in 5 mins and the mixing can was hot to handle. I might take the bondo back tomorrow and get a gallon from napa. If you want a longer pot life, mix less MEKP, it's a chemical reaction, you don't need TONS of it. The cure well happen, just slower with less catalyst Im not the one you want to try to troll. Just a fyi for you.
Amart88 Posted June 8, 2013 Author Report Posted June 8, 2013 Have you ever thinned down resin with acetone before? Where did you get this idea from? I would never thin down resin, it's not meant to be. It's not like it's a paint base thst is urethane or anything like that. You've likely ruined your wood is my bet. You're going to need to start over and use the MEKP only in the resin, as is intended. Also, you mix your MEKP based on outside temp for it to setup properly. The hotter it is outside, the less catalyst you'll need, otherwise you won't have any pot life. I think you well need to start over, I don't believe your acetone will allow the catalyst to activate properly especially since you said its not getting warm. You MAY have just slowed the curing process down, you may have prevented it from happening at all. Good luck, I'd be pissed if it happened to me. Just breathe, take a step back, and likely you will be starting over. Let us know how it goes, I'm interested. Well I only did the bottom side of one peice on the floor of my wall. It's semi hard but if I hold my thumb on it it will be tacky. The piece is PL premiumed to the truck so it aint coming out lol. I don't even see it. You got my ocd going now. The board should still be ok though right? it was only a thin layer that won't be seen, sanded or glued on. I can;t scrape any off with my fingernail but it's like painters tape. It's the bottom of this peice that i did it on. My 2005 s10 blazer build. 4 zcon 18's walled.
CleanSierra Posted June 8, 2013 Report Posted June 8, 2013 If it's tacking up, you might be ok. My guess is, you just slowed the cure process down by a lot. You effectively killed the purpose of the MEKP. It sounds like it isn't as tacky as I imagined, so you will probably be ok. Im not the one you want to try to troll. Just a fyi for you.
Amart88 Posted June 8, 2013 Author Report Posted June 8, 2013 If it's tacking up, you might be ok. My guess is, you just slowed the cure process down by a lot. You effectively killed the purpose of the MEKP. It sounds like it isn't as tacky as I imagined, so you will probably be ok. Ok, I feel stupid . Learn something new every day. If the test batch is rock hard tomorrow then I will really feel dumb lol My 2005 s10 blazer build. 4 zcon 18's walled.
Amart88 Posted June 8, 2013 Author Report Posted June 8, 2013 Well the batch i made last night was hard as a rock this morning so it must have been the acetone. go figure. My 2005 s10 blazer build. 4 zcon 18's walled.
meade916 Posted June 8, 2013 Report Posted June 8, 2013 i would like to know who told you to mix acetone in it to get the "wood to soak it up better" lol....the wood needs no help. lesson learned i guess. now go get some SunFlash and forget all of your troubles. available @ http://www.wcCarAudio.com . All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
bdog Posted June 8, 2013 Report Posted June 8, 2013 polyester resin needs to be thick build heat and set up if you put it on too thin it will take forever to set if it does at all REP
CleanSierra Posted June 8, 2013 Report Posted June 8, 2013 Id guess it's never going to setup. It won't have any strength if it does. Back to the drawing board Your brand of resin wasn't the problem, without the acetone, it would have been fine I'm sure. The Napa might be worth trying if it's cheaper though Im not the one you want to try to troll. Just a fyi for you.
AMI CUSTOMS Posted June 8, 2013 Report Posted June 8, 2013 Acetone is what is used to remove un cured resin, so yes the acetone is keeping the resin from curing it will take weeks to cure lol. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
Amart88 Posted June 8, 2013 Author Report Posted June 8, 2013 Yep lol. Lesson learned. Won't be using it ever again. Could have been a lot worse. My 2005 s10 blazer build. 4 zcon 18's walled.
