soundstream15 Posted June 13, 2013 Report Posted June 13, 2013 I may recone my SA to dual 2 so I can wire to .5ohm. I have ok enough electrical for it to run. Just wasn't sure if its worth it or not. Would be the first time running below 1ohm. I have a AQ2200
Fosgatefeind Posted June 13, 2013 Report Posted June 13, 2013 cant wire a dual 2 to .5? unless you explained this wrong Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com
Omega5002 Posted June 13, 2013 Report Posted June 13, 2013 He has 2 12'sOP, if you have to ask, then don't 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Kyblack76 Posted June 13, 2013 Report Posted June 13, 2013 Do it... there.. if you blow shit.. blame me.... Good enough? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Fosgatefeind Posted June 13, 2013 Report Posted June 13, 2013 whats your electrical? Buildlog: http://www.stevemeadedesigns.com/board/topic/146515-2007-monte-carlo-ls-build-new-plans-with-dc-audio/ TEAM DC AUDIO www.Dcsoundlab.com
SnowDrifter Posted June 13, 2013 Report Posted June 13, 2013 I think he has 2 subs?Here is what I say to everyone running .5.... You can, but YMMV. We are not you, we don't know how you treat your equipment. We cannot guarantee it will be safe.If you do it, it will not be because any of us said you can. It is because you made the choice that you are willing to risk your equipment for a bit more power. If it breaks, then accept it and move on. Don't get upset because wiring below 1 ohm has the chance of blowing things. If you are willing to accept that as a consequence and assumt all responsibility for it than by all means go ahead and do it. If not... Get another amp and run at 1 ohm each ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
soundstream15 Posted June 13, 2013 Author Report Posted June 13, 2013 Thanks guys. I was trying to make up for some rise, do I know what that is? No, but I seen someone ppl have ran at .5ohm. Just wanted some input. I will not wire down then, got no prob with that.
Kyblack76 Posted June 13, 2013 Report Posted June 13, 2013 And some run even lower...... You can do it bro.. Just dont come bitching IF somethin happens, was my point... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
soundstream15 Posted June 13, 2013 Author Report Posted June 13, 2013 I won't be bitching lol that's my fault. I just don't wanna risk it. I believe I can be fine but if something happens then I'm fucked. Rather upgrade subs then wire down. But thank you:)
