My friend just got 2 vvx 15s and they're on his hifonics Brutus 2100 and we built a box at 4.7 cbft at 33-34hz with 14.5 of port per inch and they drop of right under 33hz. Do they just need to break in a couple weeks or do these subs just need a lower tuned box to hit lows? I feel bad cause I designed this box and he's already brought up possibly selling them after 20 minutes of being in his car lol
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
2 15's in a 4.7 cu ft box? That's very small
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Well on skars website it says like 2.1-3.0 cbft for 1 15 and I figured even though 600 watts is conservative a box on the small-middle size couldn't hurt
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Mine played way down past 26hz after they broke in tuned to 31. When I first started playing them they could hardly hit 40hz. People want something to really bang with out letting them loosen up? Lol...
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
this is also true, after a while of playing it loosened up
Well first the box was a tad over 5cbft but when I was designing it I forgot to add speaker displacements (mega noob move) and we already had pieces cut when I realized I didn't add the displacements so it ended up being 4.7. I also told him to let em break in some cause outta the box they barely moved when you press on them lol
2006 Ford Explorer
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
So you didnt calculate the smaller box and how the port tuning would change because of losing a half cube
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1514 Guests (See full list)
