Box for SDC 2.5 12"
Looking for some assistance in making a box for my 12" sub. definitely want it to be ported just not sure on dimesions. is going into a 2001 4 dr chevy blazer.
2001 Chevy Blazer LS
Kenwood KDC-HD552U
2 12" SDC 2.5 D4 Fi SP4 18" 4 Sundown SA-12's
HiFonics BE 1200.1 Soundstream RUB1.2500D Looking for a 5k
XS Power D3100
4 Soundqubed 6.5's (Pro Audio)
2 Soundqubed 3-Way 6.5's
2 Soundqubed Super Tweeters
joe x
Kenwood KDC-HD552U
XS Power D3100
You need to post up your max dimensions and since joe x is such a cool guy he will probably put you a design together but you gotta give him time
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
mine is right over 5 cubes for two of them with 60 square inches of port on 1200 watts tuned to 37
does fairly well. if i had more power id like it more
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Don't forget to mention what you're powering it with and what kind of music you like to listen to
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
to break in the sub im gonna power it with a hifonics 1000.1 after about a month i getting the AQ 1200.1.
Kenwood KDC-HD552U
XS Power D3100
The break in is a myth for a sub's power handling. As long as you power it correctly you shouldn't have any problem on upgrading the amp.
Edit: however, after use a sub will loosen up changing its parameters a bit.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
okay, i was just basing it off of what AQ said.
Kenwood KDC-HD552U
XS Power D3100
So here is a suggestion, dimensions need to be checked before building, the dual layer baffle is optional, read the notes below the pic:
Enclosure Specifications:
Fb = 35 Hz
Vb = 2.5 ft^3
External Height = 15.25 in
External Width = 38 in
External Depth = 14 in
Port Width = 3 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 38 x 14
Left & Right Sides =
Side 1 = 12 1/2 x 13
Side 2 = 13 1/4 x 13
Front = 34 1/4 x 13
Back = 38 x 13
L Port Internal Assembly Parts:
Front to Back = 9 1/2 x 13
Extension = 13 1/4 x 13
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- The port needs 3" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
I really appreciate it Joe X will get back to you of I have any issues.
Kenwood KDC-HD552U
XS Power D3100
  • Who's Online   0 Members, 0 Anonymous, 1088 Guests (See full list)
