2000 Yukon wont drive while subs are playing
i have a customer with a 2000 yukon with a triple alternator setup( 1 350 amp and 2x 300 amp), 4 shuriken sk-bt140's under the truck, 4 yellow tops under the box, 15kw and 4 dd 9518's. while the subs are playing, the vehicle will not accelerate at all. we dont know where to go from here. battery are fully charged, and voltage is strong. any ideas?
I know ho alts put more of a load on an engine, but I don't think it would be as severe as no acceleration.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
i didnt think so, especially since i've heard of someone running a qaud setup on the same style vehicle. im thinking maybe because the throttle body is fly-by-wire??
While the alts will rob horsepower irs not going to keep jt from driving.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
why dont you try disconnecting 2 of the alts so there is only a load off of one alt and see what happens, i had a friend with a s10 with a dc power alt externally regulated to charge at 19.2v, he had like 6 16v batts that were almost completely dead and when we turned the regulator up on the alt it stalled the engine because the load was so much
97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
DId this install every work properly? Meaning...did this vehicle used to work with these subs and amps and alts and play bass without the issue or did the issue always exist with this setup.
The answer to the above will help to isolate what to look for. Its either some component that broken (used to work) or a faulty install. It could still be a broken component if it never worked before but this is still important info to know.
Also, when you say " while the subs are playing, the vehicle will not accelerate at all." does this mean Full Tilt or even while playing at low volumes?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
it starts at about 3/4 of full tilt. it just started, when we put this system in, it was fine when he had 4 mojo 15's and only 7500 watts, single 350 amp alt and 4 yellow tops.
and also, everything played fine for about 2 weeks, then the problem started
  • Who's Online   0 Members, 0 Anonymous, 1527 Guests (See full list)
