95 south Posted June 30, 2013 Report Posted June 30, 2013 I know it may be a stupid question but with a 270 amp alt and 2 runs positive/ 2 runs ground to the rear should I do 2 runs of 0 gauge wire from the alt to the battery? No System......GFY
Kyblack76 Posted June 30, 2013 Report Posted June 30, 2013 What runs DO YOU have from the alt to the front battery ??? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
tacomaguy1 Posted June 30, 2013 Report Posted June 30, 2013 One from alt to front battery is sufficient One run will carry the 270a from the alt just fine Team Flex Issues
95 south Posted June 30, 2013 Author Report Posted June 30, 2013 Right now I have 1 run of 0 gauge from the alt to the front battery. No System......GFY
Tarball Posted July 1, 2013 Report Posted July 1, 2013 You're good as long as you have the other 2 components of the Big 3 done. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
95 south Posted July 1, 2013 Author Report Posted July 1, 2013 That's the problem. Where am I grounding the other 2 wires? The side frame of my SUV is not good and I don't know where to ground the engine? Its driving me nuts because it seems no matter how much wire I run my voltage drops fast due to poor grounding up front. No System......GFY
Tarball Posted July 1, 2013 Report Posted July 1, 2013 Ground your battery and your block to the same spot. Ideal spot is a thick heavy metal part of the frame. Take some pics of your engine bay. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
fecupe2001 Posted July 6, 2013 Report Posted July 6, 2013 depends on the resistance, but let me tell you, we added 2 more extra runs from alt to battery, now my teammate has 2 pos and 2 neg from alt to battery and did a BIG difference Big3? not bad, i always recommend doing at least the big4, same big3 but adding a run from alt to battery, that helps a lot , specially when you have an aftermarket HO alternator I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
95 south Posted July 6, 2013 Author Report Posted July 6, 2013 Maybe this will help my voltage problems. No System......GFY
