Zak Massey Posted July 6, 2013 Author Report Posted July 6, 2013 I have 2 zx2500's but the birth sheets are more then 200 watts apart and Ill be pushing them each to their limits really '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
AA98hoe Posted July 6, 2013 Report Posted July 6, 2013 how can polarity be a problem if 1 sub is in and each sub has its own chamber? unless I misread On dvc subs you can have one coil in phase the other out of phase an it will heat that sub up quicker than shit with hardly any output .. Double check your wiring op TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Guest Posted July 6, 2013 Report Posted July 6, 2013 I have 2 zx2500's but the birth sheets are more then 200 watts apart and Ill be pushing them each to their limits really more than 200 watts? so what? tune the amps with an oscope/dd1. find which amp has the lower AC voltage output, then lower the gain on the one that has the higher AC voltage output til they match. done. edit: now knock that center partition out and put bracing. shared airspace > separated.
Zak Massey Posted July 6, 2013 Author Report Posted July 6, 2013 I'm fairly new to the car audio world, I had just heard that if the amps ran different powers then you should have the subs in seperate chambers, so I guess ill be knocking out that bit and open up the airspace some. '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
SnowDrifter Posted July 6, 2013 Report Posted July 6, 2013 Do the pop test with a battery. Both subs should move out. I like to use a car battery, it's most obvious ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Zak Massey Posted July 6, 2013 Author Report Posted July 6, 2013 Okay guys, my polarities are all correct. What now? :/ '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
DylanBunch Posted July 6, 2013 Report Posted July 6, 2013 how can polarity be a problem if 1 sub is in and each sub has its own chamber? unless I misreadOn dvc subs you can have one coil in phase the other out of phase an it will heat that sub up quicker than shit with hardly any output .. Double check your wiring opdid not know that 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Jessica Posted July 6, 2013 Report Posted July 6, 2013 If you are runnning an amp with to each sub then you need to gain match. Simply unhook the subs, put a DMM set to ac volts to the speaker terminals and adjust the one with the higher voltage down to match the lower one. I don't know if the zx2500 is strappable or not, but that is also an option. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
SnowDrifter Posted July 6, 2013 Report Posted July 6, 2013 Measure your box and post the various dimensions here. sometimes it happens that what you build might have ended up being different than the real results ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
CleanSierra Posted July 6, 2013 Report Posted July 6, 2013 What IS your voltage like at the amps? Id test that with a DMM. Also, you need to have those gains set properly on that amp. Get in touch with someone with a DD1 or O-scope. Then if you do the shared chamber box, you need to gain match the amps. Im not the one you want to try to troll. Just a fyi for you.
