Zak Massey Posted July 4, 2013 Report Posted July 4, 2013 I have one of two Fi Bl 18's in a wall and have noticed that there is a ton of heat building up after a short period of play on both test tones and music. The box is 5 cubic feet (probably a bit on the small side) and the sub is being powered by a Kicker ZX2500.1. Also the sub seems to have only a small amount of excursion and I don't feel like that's the way it should be... Any help you can give me would be appreciated! Thanks! '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
Kyblack76 Posted July 4, 2013 Report Posted July 4, 2013 Time out.. you have 2 18's in a 5cu enclosure? Also, the way a driver "cools" is by moving.... lil movement, lil cooling.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted July 4, 2013 Report Posted July 4, 2013 Box spec's.. VOL, Tunning, port per, all that.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Zak Massey Posted July 4, 2013 Author Report Posted July 4, 2013 No, sorry they are in separate chambers 5 cubes per. The chamber is 21 deep x 18.5 wide x 19.5 tall the port is 21 deep x 18.5 wide x 2.5 tall. After displacement and all that jazz the chamber is 5.01 cubic feet and the port is tuned at 31.2 hz '03 Cavalier LS Coup DC Power 270xp alt 2 Sundown Neo Pro 8's 2 Selenium ST200 tweeters 1 Sundown SAX-125.2 1 CT Sounds 125.2 2 Fi Bl 18's walled 1 CT Sounds AT7000.1D
zydrix Posted July 4, 2013 Report Posted July 4, 2013 If I'm not mistaking FI tend to like bigger boxes, u should have about 6-7cu chamber per 18. (depending on power ran). My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
CleanSierra Posted July 4, 2013 Report Posted July 4, 2013 Do you have anywhere NEAR the right amount of electrical upgrades to support 2500 Watts? How was your gain set on the amp? Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted July 4, 2013 Report Posted July 4, 2013 Give us pics of the box as well, that will help. Seems like port area might be low too for that sub. Im not the one you want to try to troll. Just a fyi for you.
CstrokerV Posted July 4, 2013 Report Posted July 4, 2013 might of mixed up polarities on the subs too so the coils could be fighting each other my build http://www.stevemeadedesigns.com/board/topic/142505-small-build-log-4-dc-lvl3-10s-tl-update-link-to-rebuild/ http://www.stevemeadedesigns.com/board/topic/154258-rebuild-6-lvl3-12s-update-small-video-nothing-spectacular/ new build http://www.stevemeadedesigns.com/board/topic/188181-03-trailblazer-slow-build-8-dc-lvl3-12-m1-motor-m2-parts/
john253a Posted July 4, 2013 Report Posted July 4, 2013 clip city turn the bass boost off, and as clean said, elect. and get the gain set with o'scop or dd1
notorious97200 Posted July 4, 2013 Report Posted July 4, 2013 2500 per sub ? That is way too much for a BL, for music. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
