Suicide P Posted July 16, 2013 Report Posted July 16, 2013 Hey guys. I got my bionics brx1100.1d today and I'm putting it at one ohm on a sa12. The thing is.. when im setting the gain anything other than .2 gets quieter. So if I slowly turn the gain up its automatically getting quieter (subwoofer is).
Suicide P Posted July 16, 2013 Author Report Posted July 16, 2013 On my phone so autocorrect is getting the best of me. Hifonics ***
Smoove Posted July 16, 2013 Report Posted July 16, 2013 get a dd-1 and follow the manual 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Suicide P Posted July 16, 2013 Author Report Posted July 16, 2013 Definitely don't have the money for a dd-1
REVOofRustler Posted July 16, 2013 Report Posted July 16, 2013 If I'm not mistaken, .2 would be the gain knobs max setting. The numbers on the gain knob (i.e. 6,2,.5,.2) are relating to the HU output voltage. So if you had a head unit that had 4 volt RCA pre-outs, you'd want the gain to be somewhere around "4". That's a pretty inaccurate way to set the gains, though. I'd recommend finding someone with an O-Scope or a DD-1 to help you out. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
Skater229 Posted July 16, 2013 Report Posted July 16, 2013 Find someone in your area that has one? 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
Smoove Posted July 16, 2013 Report Posted July 16, 2013 if you go to the tools topic. there is a map where a lot of people are willing to help you with thiers. http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Guest Posted July 16, 2013 Report Posted July 16, 2013 .2 is max gain. 6/8 whatever it is on that amp, is minimum gain.
ChevyBoy95 Posted July 16, 2013 Report Posted July 16, 2013 That amplifiers gain ranges from a 9v (lowest) to .2v (highest). What you want to do is turn it all the way to 9v being the lowest. Hopefully someone in your area has and oscilloscope that you can properly see the wave as you turn the gain to make sure it is not clipping. One of the typically ok ways to set it for the time being is to attach a DMM to your RCA going into the amplifier. Positive probe on the tip, negative probe on the outer ring. Play a 40hz 0db tone through the headunit and turn the headunit up to 3/4 volume. Record the AC voltage seen, it should be just under your preout voltage. Then on your amp, turn the gain knob to wherever you think that AC voltage is. (say if it was reading 4.5v AC, you would put the gain at half on your amp.) Then turn it down a hair from their (turning the gain down means turning is slightly towards the 9v side.) This should be ok for the time being until you find a proper person to set the gains with a DD-1 or oscope. Keep an eye on the sub and amp, making sure you dont smell coil, and the amp is not overheating. Hopefully this helps a bit. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Suicide P Posted July 16, 2013 Author Report Posted July 16, 2013 Oh I was misinformed by people. That makes more sense. No one is close to me in Washington.
