not trying to be a dick, but oh god. you just achieved donk status.
now look, if you want to actually get loud, use less woofers and use a ported box.
I'd like to see the isobaric approach. It would be pretty mean to see 3 subs, compound loaded and only needing the space for 3 subs. If the power is on tap, its definitely the direction I would go :D
He aint givin up no subs he wanted 10 and settled for 6 lol
Compound loaded means there are 6, loaded as three. They would either be push/push, or push/pull configured. I'd do push/pull so no tunnel would be needed.
well yeah.
but what im saying is, most people would rather have performance over looks. performance being loudness, and looks being amount of speakers.
I'm sorry I am so noob that I have no idea what that is
do you have a link somewhere that explains it?
http://www.the12volt.com/caraudio/boxes2.asp#3 gives a decent idea.
Not disagreeing, but we all have to learn somehow. Some people have to see it for themselves.
He's going to move some air and probably even be happy, which is all that matters. Eventually he will have to realize that he needs to make changes to get louder just like you're telling him.
well DONK status has been achieved. Post numbers and we will get a guy with 2 of those subs in a ported box to beat your score.
Also, IF YOU were to use 6 woofers. The Push pull idea is a good one. Might take a box genius but that is a really good one
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
6 12's on 3500w better do atleast a 50 or its a fail, I metered dyablo409's old car a while back and it put up a mid 40 with 2 12's on a rf1500 so I would expect nothing lest with more than double the power and 3x the cone area. When you cant break a 40 flat you'll realize you shoulda listened to up and done 2 beast 12's ported instead
Used to have a loud truck
I musta missed where he said power...
My next goal is a 48 out the trunk, under 3k
I did a 45 with 2 12's in a ported box with a port and bracing that flexed on a 2.5k after demoing for 4 hours and waiting till 2pm in Texas heat to do my run.
If 6 12's on 3.5k doesn't beat my 45 in my much less then ideal senecio then maybe you will be convinced then.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
