Guest Posted July 26, 2013 Report Posted July 26, 2013 my 99 monte's driver window usually works but sometimes when going either up or down, the window will slow down then stop like a half second later. the passenger window is completely fine and the motor is original. the driver window motor has been replaced like 7-8 years ago. i've read that sometimes the window control switch goes bad for my car so i bought a new one. problem still occurs. any ideas guys? p.s i didn't know if i should have put this thread in this section, or the interiors section.
masterkiwi Posted July 26, 2013 Report Posted July 26, 2013 have you cleaned the switch? Now why would you clean a new switch?
Guest Posted July 26, 2013 Report Posted July 26, 2013 I cleaned the original one and it still had the issue. so I bought a brand new oem one like four months ago and the issue is still there
boom50cal Posted July 26, 2013 Report Posted July 26, 2013 Not sure if it would be fused anywhere, but its worth checking along with the condition of the switch wires. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Airborne Posted July 26, 2013 Report Posted July 26, 2013 7-8 years is not new for modern electronics. And I cleaned the contacts with contact cleaner on my wifes Elantra when I had a similar issue and it went away...
Pioneerchuck Posted July 26, 2013 Report Posted July 26, 2013 Have you tried testing voltage and resistance at the switch and from the switch to the connector on the motor? If you could get it to happen while you were testing and nothing was wrong then it might lead to the motor being the cause of the problem.
kickass audio Posted July 29, 2013 Report Posted July 29, 2013 Have you tried to use the switch in the door and move the wire grommet that feeds the wires through the door panel around to see if it makes the window lose control at all? I would see maybe if you can get a friend to help with this by having them hold the window up or down button depending on the position of the window and move around the wires that get fed into your drivers door to see if it affects the window. Then take the passenger door and do the same thing by moving the wires around a little where they get fed into the door to see if it stops it at all. If it does that means you have either a cut or exposed wire and it can be fixed easily. Another thing to try is to double check the grounds on the motor. My ex's piece of shit honda had one window that would be slow sometimes and other times would not work at all. I found that by slamming the door really hard it would get it to work just fine for awhile then get back to screwing up. The grounds were all tight and rust free so idk what was loose in the door but slamming it was a temp fix. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
