Ok so i want to set my gains but i have a soundstream bx15 and a pac lc1 rca bass adjuster and want to know how i woud go about doing that also do i pit the pac lc1 before the episenter or after like from my hu to lc1 to bx15 thanks
I would do the LC-1 after the epicenter personally.
x2.
The best thing to do is either with a DD-1 or a scope.....
check for signal clipping after the HU, then check for signal clipping after the epicenter on full volume un clipped HU volume, Then with HU at full unclipped and epicenter at full unclipped, plug into the LC-1 and max out the LC-1 knob, then plug the RCA's into the amp and set the amps gains. LC-1 doesnt alter the signal, it just regulates the voltage.
edit: and you will want your epicenter flat when you set the gains. And remember, it is better to lower the peaks, then it is to boost the valleys in a response curve with an epicenter.
Edited by ChevyBoy95
I've said this right here. And most times, get crickets. Lol.
But you are correct. Don't boost. Lower surrounding freqs. ;)
lol, i just said that.... haha.
but it is good to see multiple people on the same page.
