subs divided or combined ??
mejweez
am planning to bulid a ported box for 2 JBL 12" (P1224) but am confused
what wil be better a box that has a divider for each sub so that they are sealed from each and each one has it's own port
or
combined with one port ??
what do u recommend
combined
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
X2 on combined, but I would do the port between the subs for a daily music box.
Current system:
Previous systems:
Or you could even do separate chambers for the subs with a center port that's shaped like an L into each of those chambers.
What's the setup though? Vehicle, orientation, etc?
rockfordfosgate R1200.1d
2 12" JBL P1224
2004 Hyundai elentra
2 12" JBL P1224
Are those subs dual 2 ohms wired to a final load of 2 ohms at the amp? Tried googling and the JBL site says that they either come 2 or 8 ohm but that they're DVCs. And what's your goal? Just a daily vehicle for you to listen to?
2 12" JBL P1224
they are dual 4 ohms the final load for the two subs will be 1 ohm 800 RMS
i listen to rap usually , and yes it will be for daily use
Sealing the trunk = making sure that all of the empty airspace in the trunk stays in the trunk. Box gets pushed all the way up the the front and then you seal off all the airspace around it with panels/foam/however you want to do it. Basically reduces the size of the cabin
  • Who's Online   1 Member, 0 Anonymous, 1014 Guests (See full list)
