amp not drawing enough amperage
So I have a AB 750.1 @.5 ohm
My voltage drop is about 13.5-13.6 at the back batteries at my peak frequency. Everything else stays around 14v full tilt. my voltage meter is calibrated and accurate.
My electrical consists of a dc 180 amp alt, 2 stinger spv 44's, and a kinetic 1800. 2 runs positive and no dedicated neg runs.
Am I crazy or should I be dropping more? I remember my crunch 3000d at a quarter ohm would give me more voltage drop than this amp. But then again I only had one battery in the back and one run of positive..
Anyways, help me out guys!
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Have you clamped output? Maybe you're not wired to half like you think or rise is just keeping your setup safe.
On a 7,500 watt amp with a 180 amp alternator and three batteries...yeah, no difference in voltage should be evaluated.
Complain because im not dropping LOW ENOUGH.
is it loud?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
The amp gets warm to the touch. So I know it's not backed off THAT much.
Checked with my pos multimeter and my impedance is exactly .5 at the amp after checking the resistance of the leads.
And no, I'm not complaining, I'm concerned.
Edit -Yes, it's quite loud. Last time I got it on the meter it did a 49.9 at 38. Score is higher now after a lot of changes though.
(1) Mechman 240
TEAM NWSPL
155db outlaw
Also forgot to mention I'm dropping from a resting voltage of 15v. So there is about 1.4v of drop. Little less sometimes depending on the temperature outside.
(1) Mechman 240
TEAM NWSPL
155db outlaw
Box rise is a bitch.
Theres also a hugeee differance between .25 and .5
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
