DC Sound Lab
DC 10k amp hum at low gain
I had a dd-1 but the shops setting with N is cope , i just don't think only 1/4 gain is where the 10k starts to clip,
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
Yeah but that don't matter. It will clip at a different point depending on your setup. HU, RCA's and line voltage.
My Nendo 3500's clipped at 65% gain in my old build now they clip at half.
Edited by Amart88
iPad as h/u and Jl cl-rlc line driver , maybe could run through the bit one
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
And all RCA are the same no difference in signal from a coat hanger to mos expensive rca
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
All I am saying is the gain in not a set level. It is to match your RCA output voltage. If you have low voltage the gain would need to be a bit higher to compensate. etc.
I have very high o/p voltage
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
There you go. Just answered your own question.
The gain does not have to be high for the amp to do it's rated power. You are likely fine at 1/4 as that's where it matches up.
My 9k hums when the DD-1 shows distortion.So if your amp is humming then that mean your hitting the point of distortion. The amps gain is only there to match the amps output to the source unit. So if you have bass boost turned up or your line driver turned up then your amp wont need to be turned up much to match the input signal.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
Please no shitstorm.....
Does the amp actually hum? or the subs it is hooked to?
Yupp the amp actually hums. Very slight though
edit: My 2200 did hum aswell
Edited by DubinDodge
  • Who's Online   1 Member, 0 Anonymous, 816 Guests (See full list)
