Sky High Car Audio
I have the 16 ton. Highly recommended
Thanks snow I hope these are worth the extra 20. I just ordered the 16 ton I posted.
Let us know what you think of it and what the biggest wire you can crimp with it in real life situation is. OFC wire of course
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I use 50mm^2 most of the time, or 70mm^2, either is what you would need for 2/0 plus a solid copper lug, all depends on lug thickness which will work best
Cheapo brass split terms I sometimes can use 35mm^2 for standard "0" or "1/0"
YQ-___ = the # is the largest die in the set in mm^2
I prefer the 12/16 ton because of the "H" pin design is better IMO vs the "C" style like the 8ton
I just ordered the one OP posted. Will see how it works,
Thanks for the sizing eval ^^
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
This is the one I have
http://www.ebay.com/itm/Hydraulic-Crimping-Tool-Kit-16-Ton-Wire-Cable-Crimper-/330554371671?pt=LH_DefaultDomain_2&hash=item4cf6936e57
Crimps down to 4ga. I usually don't end up putting terminals on anything smaller than that and I decided to optimize for what I would mostly be doing, which is 0 gauge or larger, and the occasional 4ga. 8ga and smaller, it's just easier to give it a zap with a soldering gun
This is the one I havehttp://www.ebay.com/itm/Hydraulic-Crimping-Tool-Kit-16-Ton-Wire-Cable-Crimper-/330554371671?pt=LH_DefaultDomain_2&hash=item4cf6936e57
I should have said only crimp up to, not down to. My bad. I meant that the largest wire it will crimp is 6 a
