Built My First Box Today
g2shuck
Oh I forgot to say what sub is going in it. It will be a soundqubed sdc2.5 12 that will be receiving 500 watts from a kicker 10zx500.1. I know it is not the best amp but could not pass it up for $50. Car is a 2000 Toyota Camry.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Cool man. Good job on the first box. I am too lazy to read through what's already been suggested. But here's my advice. Predrill holes before you screw. And use small screws. Also I only use like 1 1/2" long screws.
Try and use the least amount of screws as possible, they're not needed most of the time. I only use them when I need to secure a joint that I can't get a clamp in there with. Which is usually the port walls.
And scrape off that dried up glue from the corners. Or run your finger along it and smear it into the edges, that's what I do.
Also invest in a router with flush trim/roundover bits. You will love it.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
And if you are going to invest in a router, make sure it is a plunge router. You also might as well get a jasper jig to cut those perfect circles ;)
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
thats one reason why i dont use screws =D
looks good
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
looks good
Yup. But I don't have a jasper. What I do to draw out my perfect circles is find the center of the baffle, drill a small holes in the middle of where the sub will mount. And measure out the radius of the cutout onto a thin piece of MDF, and drill a little bigger hole for the pencil to slide into. Then drill through the thin piece and slide the drill bit into the hole i drilled in the middle of the sub cutout. I suck at explaining shit so I'll try and find a picture.
Then I just skillfully go around with a jigsaw ;) Lol. I can make pretty good circles imo.
Jigsaw-cut circles. Box I just built for a friend. All edges rounded over and flush trimmed.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
I did the same thing basically. Yeah, as long as you take your time with a jigsaw, it can look flawless
That is actually exactly what I did. Then I smotthed it out with a sanding drum on my die grinder and It cam out almost perfect.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
  • Who's Online   0 Members, 0 Anonymous, 449 Guests (See full list)
