Reverse Polarity or use -3db setting on tweeter crossover
Smoove
Also ... How good is your EQ !??
No EQ settings, bass and treble set to flat 0 on everything. I will check the wiring to the passive crossovers this weekend and make sure the same. Tweeter option on the crossover is 0 or -3. I am at 0 right now.
I have also thought about trying out the EQ feature on my Alpine 9861.
I'm sure for the most part, this can be fixed with EQ ...
We've spent hours and hours of EQ time on my 13 band ...
When I pulled my door panels to get to the crossovers I found I was already at -3db. So I reversed the polarity and that helped quite a bit. Then I decided to go through the manual for HU. I don't if I missed this setting years ago when I installed the HU or not. But there is a setting that states "for better sound quality when using amps, turn off the internal amplifier". DOH!!! So my Alpine doesn't like sending signal to the low output and the high output at the same time. Turned off the internal amp on the HU and now it's way better. My ears are no longer getting shredded on certain notes. any tuning after this will require some sort of processor. I might pick up a used OEQ-1 since they are cheap on ebay.
nice, glad to hear you found a solution, and even better, you came back and shared it with the forum.
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
  • Who's Online   0 Members, 0 Anonymous, 826 Guests (See full list)
