Reverse Polarity or use -3db setting on tweeter crossover
Smoove
I have Infinity Reference 6020cs 6.5-Inch Two-Way Components with passive X-overs. Running off an RF 300s. Amp set with a DD-1 at -0db. For the most part the components sound good. There are some notes that feel like they are ripping through my ears. Turning down the treble on the deck makes the components sound like crap. If I turn down the gain too much the highs cant keep up with the bass. So here are my choices for taking the edge off the tweets.
1: Set the tweet @ -3db at the crossover
2: Flip the positive and negative at the crossover
3: do both 1 and 2.
I am not ready to buy a processor and go active yet. Need $ for that to happen.
the only way to tell is to go ahead and run through your list, see if it helps and if not then you'll have to find alternatives, I recently went active with a audiocontrol 2xs . I had to change the crossover modules in it to fit my application, they come set at 90 hz and 33hz, for a few bucks I made my own modules and set it at 3750 for cross over point and 60 hz as my cut out, all was done for $105 bucks, not that bad if you ask me.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
Try all combinations and see what sounds best. I'm the person who throws numbers out the window in times like this. None of what you listed is necessarily harmful, so just see what sounds best to you
It sucks, sounded great day 1 and 2 days later my ears are killing and the high peaks are more obvious. How does reversing the polarity make highs less peircing?
I was also wondering, what are the potential advantages of clicking in that -3dB switch on my passive crossover for my JBL P660C like OP is thinking of doing? I have it set at 0db right now and always have...does it help for imaging with the mids when they are mounted further apart? or just generally helps to blend music together? My crossovers are inside my door panels so rather not re-open them just to play with the button and see the difference in sound lol
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
You can try a combo of all of the above, but I agree with ScottishBear.
I would put the tweets on the -3db setting first and give that a try for a while. All that does is lower the output of the tweeter and leaves your mid alone.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
There is no answer without trying it.
Eclipse cd7000
I will test this weekend, I gotta pull the door panels to try both options.
Sounds to me like your tweeters are completely out of phase ...
You check to make sure that your components are in phase ??
  • Who's Online   0 Members, 0 Anonymous, 735 Guests (See full list)
