Making 8" PVC ports. Flare Achieved!
P4killer_
Ok I want to make 8" aero ports As well as 10" if possible. I picked the tube up from local plumbing supply. We tried heat guns 2 at a time both on low pulling like 6a each so we couldnt go high on either.. we tried boiling water not much happened. Switched to oil we got results but not withoutime error.
Tbh I didnt have much time at all to play around so im trying to gather information before we try again next week.
Things im mulling over:
Is the pipe too thick?
Are we heating the iinside of the tube too quickly versus the outside of the tube?
Would a single heat gun on high which iirc is like 1200F lol something idk, would that be better than the two guns on low?
Oil temp too high or low?
Is the bowl too steep? I saw a wider less steep bowl like a salad bowl as opposed to this like large mixing bowl.
Looking for ideas please.
Pix first then vids. They likely wont embed right since im on mobile so ill fix that later
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Setup:
Xs D3400/ Xs XP3000
I've used one heat gun on high holding it as close as I could to it without burning it while spinning the PVC on the bowl slowly. It takes some time for sure. But when you're done pour cold water down in the PVC while holding it on the bowl to retain the water, also pour cold water on the outside it will cool it down quick and keep it shape better
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Setup:
Xs D3400/ Xs XP3000
Wow it all embeded right. Look at that.
Setup:
Xs D3400/ Xs XP3000
Yea ill try that. This pipe is pretty thick imo like 1/4 inch I dont wanna be there for like 2 hours.. did you use similar pipe and about how long were you heating?
Thanks in advance to any and all btw
Setup:
Xs D3400/ Xs XP3000
I wonder if fiberglass would work? Instead of using the bowl to shaped the pipe use the bowl for the flare and fiberglass it all then you can trim it down to size and hit it with rage and smooth it out an your done or you can use resin to smooth it out
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
