Sergeant_Skyrim Posted August 24, 2013 Report Posted August 24, 2013 EDITED: New question in post #13 Was sitting at 11.50 before I pulled it earlier today before work, and was at 11.54 before I put it on the charger an hour or so ago. It's now at 11.67 and going very slowly. Is this normal? I've never had this happen before so I don't know how long it's going to take to charge back up. I'm hoping I haven't fried it completely but I don't know... Am I okay to leave this on the Battery Tender Plus charger over night? Planning on also checking the Interstate under the hood that was 10.x earlier today and somehow miraculously sat at 12.94 after I did my shift at work (delivering pizzas) after it had sat for a half hour or so. Gonna check that in the morning to see what it sits at after a full night of rest but it's not looking good for the XP right now. Looking for some guidance, but mainly wondering if it'll be fine to leave on the charger over night. Hoping I didn't fuck up too bad but if I did it's on me...some lessons are more costly than others Edit: It's been at 11.67/68 for the past 10 or so minutes as well, don't know if it's gonna go any higher so I'll prob update with voltage in an hour if I can keep myself awake that long... Build in progress
Real96SS Posted August 24, 2013 Report Posted August 24, 2013 I personally wouldn't use anything other than an intelli charger. Those trickle chargers don't have a float mode that i know of and they basically do exactly what its doing now. It slowly recharges it and it could take all night or a whole day. Invest in some form of an intelli charger and you will be alot happier Vehicle 2007 Chevrolet Avalanche(Co-Co) DNX9980HD 6 Team Fi 15's(King Edition) 3 DC 9k's 8 Nendo PWX 8's 4 Custom Steg 4" Super Tweeters 1 DC Audio 175.4 1 DC Audio 90.4 Rockford 360.3 3 DC Power 370xp Alts(Externally regulated) 21 D1600's 2 D4800's All SMD RCA's AudioTechnix Deadner Viper Alarm My YouTube- http://www.youtube.c...NG?feature=mhee Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/ Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
SnowDrifter Posted August 24, 2013 Report Posted August 24, 2013 If it's a dead battery it's totally normal. Unless you have a 20 amp plus charger on there it's going to take at least a day. Should be fine to charge over night ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Sergeant_Skyrim Posted August 24, 2013 Author Report Posted August 24, 2013 If it's a dead battery it's totally normal. Unless you have a 20 amp plus charger on there it's going to take at least a day. Should be fine to charge over night 1.25A 12V charger. I have to work again tomorrow at 4 lol, let's hope the Interstate isn't dead! Ironic thing is I need to work so I can make money and buy 1-2 more XP's like I was planning but being out of commission like this I can't work -.- Build in progress
SnowDrifter Posted August 24, 2013 Report Posted August 24, 2013 Yeah it will probably take a solid 3-5 days to charge. Assuming 24/7. Just hook the thing up and check it every 6-10 hours ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Sergeant_Skyrim Posted August 24, 2013 Author Report Posted August 24, 2013 Just got back ended up going out for a bit. It's up to 11.80 now and slowly climbing! I'm sensing from your post Snow that I haven't actually completely killed it yet and that it can be brought back to life, so to speak? Build in progress
SnowDrifter Posted August 24, 2013 Report Posted August 24, 2013 Should be able to bring it back. Having a larger charger would be an advantage here since you can do a couple charge/drain cycles in a reasonable amount of time. Let me put it this way: I have never encountered an AGM battery that I can't bring back. Maybe not to 100%, but certainly enough to be usable and still function as designed ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Sergeant_Skyrim Posted August 25, 2013 Author Report Posted August 25, 2013 My new question is how high should I charge it before I take it off? I am going to try to do the charge/drain cycle you're talking about and just have no audio for the next few weeks while I wait to buy another XP3000. Learned my lesson, I can do without music for a while so I can rebuild a strong electrical. So what do I charge it too, and then what do I let it fall to before recharging again? Anyways here's a pic of what's going on so far: Build in progress
Kyblack76 Posted August 25, 2013 Report Posted August 25, 2013 Now,.. hopfully it will hold it.... Under 11 and change is LOW. Like, id call dead,..but.... maybe you got lucky..... Good luck buddy, and hope it works for you. AND GET MORE BANK !!..lol... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted August 25, 2013 Report Posted August 25, 2013 Charge to around 14v Drain to 11ish. Charge again. Do this 2 or 3 times ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
