Smokey619 Posted August 25, 2013 Report Posted August 25, 2013 I have a Alpine SBR-S83V subwoofer final impedance of 4 ohms, I want to get another one exactly the same and wire both of them down to 2 ohms. How can i wire it down and make it look clean without having wires sticking out of the port. I have an Alpine MRP-M500 class d amp with only the + and -. maybe this pics can help somewhat and people familiar with the alpine subs.
Tecomah Posted August 25, 2013 Report Posted August 25, 2013 Hook the wires from the voice coils to two bolts, one for positive and one for negative through the box and hook two wires to the other sides of the bolts and wire them to the positive and negative of the amp 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
SnowDrifter Posted August 25, 2013 Report Posted August 25, 2013 Looks like there are terminals on that box. Just use those. Not sure why you'd run the wires out of the port ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Smokey619 Posted August 25, 2013 Author Report Posted August 25, 2013 this is the wiring diagram from sonic electronix, this is what i mean that i dont want to run the cables out from the port since i plan on getting another one
Noel989 Posted August 25, 2013 Report Posted August 25, 2013 Looks like there are terminals on that box. Just use those. Not sure why you'd run the wires out of the portWhat he said Build Log - http://www.stevemead...-cruiser-el-pt/
Smokey619 Posted August 25, 2013 Author Report Posted August 25, 2013 but if i connect two subs that read 4 ohms they wont go down to 2 ohms when i connect them to the amp, its just going to be 2 subs connected together at 4 ohms. I need to wire both subs together and make them read 2 ohms so i can push 250 rms to each sub instead of 150 rms to each sub.
Smokey619 Posted August 25, 2013 Author Report Posted August 25, 2013 Ok, if I hook the positive from sub 1 to positive of sub 2 and negative from sub 1 to negative of sub 2, a total of 4 wires the amp, it will read 2 ohms?
MrSkippyJ Posted August 25, 2013 Report Posted August 25, 2013 it works fine if you connect it at the amp. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Smokey619 Posted August 25, 2013 Author Report Posted August 25, 2013 Cool, thanks and what are all those wiring diagrams for then if they can just be hooked up together no need to run cables from 1 subs voice coil to the other sub and then to the amp
Torres Posted August 25, 2013 Report Posted August 25, 2013 they're not illustrating to run them from speaker to speaker. they're illustrating how the wires are attached themselves (positive to positive, etc). many people would have them in the same box where attaching them from one speaker to another is the most logical way
