Network cable not connected message. ITS CONNECTED!
Long story short....
trying to get me work shop computer going, worked fine when put away a year ago. Went to connect to my network today.
Network is fine, wireless works and ports 1,2,3 for LAN connection work. I plugged into LAN socket 4 and the light FLASHES green unlike the others which are solid.
go to the desktop and it says the connection is unplugged though it is plain as day connected!!!
Connection is plugged in and the cable works as I tested it on another device.
here's the kicker, I tried plugging it into my old as lap top and it showed as limited connectivity and I was not able to renew my IP. Toss the old dongle on the lap top and she connects to the route with no problem!!
WTF!
help, please!!!!
Rolex you sicken me.
Just let me finish my pie
~ Juice
I would say to reinstall your device driver for the network card.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
No conflicts with the Ethernet adpatyer in the PC
d5076e07-6cc1-4b6a-8b4a-75d7b7b70800_zps
this what I get
On the lap top when connected to the cat 5 this is what I got:
Unplug the cat 5 and go on wireless to the lap top and she worked no problem!
No, wireless isn't an option for the pc. Like I said, the network is solid and I know the cat 5 going to the PC is 100%
~ Juice
Jiggle rhe power cord
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
How long is the run of cat5? I believe 50 feet is about the longest you can use And still have good connection.
That's definitely false statement. Your telling me big ass companies that have their entire network wired with cat5 are in 50ft increments. I have a run of 100ft that runs from my modem under ground to my garage since my wifi can't go through the house and garage. When its connected I get better speeds off of that cable than my wifi.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Spoken like a true IT Guy
As far as cat5 runs..........
You can go hundreds of feet. My TV's (3) are all connected to the same router via cat5 wall fished up two stories to an attic and then feed back down to them on Rj45 connectors I cut. I've got 12 runs of cat5 throughout the house and the shortest, other than this computer, is 100 feet.
~ Juice
From what it sounds like on your computer maybe there is a wiring conflict if you made the cables yourself. Did you buy them pre-terminated or did you terminate them yourself? If you did it yourself then try to look through the plug and see what the wire color's are laid out as. I know it worked on another device but if the wire is wrong it can cause it to work if the card set it to a different speed where the faulty wires are not needed (ie 10mbps full/half do not use all 8 wires like 100mbps half/full will.
And for your lights you were looking at, did you check the NIC lights on the faulty computer? One indicates it is getting a signal the other indicates the transmission/reception of packets.
  • Who's Online   0 Members, 0 Anonymous, 1532 Guests (See full list)
