Yukon XL + Rockford Fosgate, Atomic, Sundown, XS Power, Sky High, /////Alpine, Digital Designs
I guess ill start with some box build up pics...
This box took 6 sheets of 49inch by 97inch MDF, there is very minimal scrap from building the box, most scrap was from the woofer cut out holes.
Box baffle is 3 layers thick, 1 of the layers is the flush mount for the woofers.
Everything else is 2 layers thick, with a 3rd layer strip down the middle of the inside and 45s for more internal bracing.
Im not one that is into wooden dowels and threaded rod for bracing, so I resort to other tricks that I personally think is cleaner looking.
Paul sitting in is new box im building. Again dud is 6'8" and about 400 pounds for a size reference, and can hold a SMD sub up in the air with 1 palm :D
Resin and sanded smooth inside and out.
Reason behind doing the outside is for a couple reasons, main reason is so that the box is not as prone to water damage from any flexing windows, doors or hatches if its being played when its raining and so it will give a great surface that wont soak up tons of primer and paint.
nuts!!!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Also ordered a 200 foot by 40inch wide roll of Suntek Carbon 5% tint.
Put 5% tint all the way around, and over the factory rear tinted glass as well which makes it about 3% in the rear.
This is a quality tint, not some autoparts store type tint that says its "limo black" but only 20%. LOL
Suntek tint next to my Madico 20% and 35% rolls of tint.
for the rear windows I needed something to roll the tint out on so I made a makeshift table with a smaller table, a bird cage, gorilla tape, and 2 old aluminum bussbars
It started to get dark out but worked out okay for cutting the tint on the outside of the window, the light you see inside the truck is my LED work light. and FYI its a 25watt LED 2000 lumens... LOL
and here you can barley see the rear dome light
where did you get the roundovers from? ive never seen anyone do anything like that. box looks badass with those monster roundovers!
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
I don't know how much more love you need to get to post more pictures, but I could crate up and send you one of my hoes if it'll get you to post more pics. That box is the sex!
