Need help cutting wall to trunk
brian85578
I cut 3 1/2" out of the opening on a 500hp car, haven't had a problem. If you are really that worried, just don't do it. GO smaller on the build.
^^^ that is very true.
But then again...pictures would be a must with this kind of question. Why would you ask a question as serious as this and leave it to our imaginations?
Sheetmetal = DO IT. Shits like paper anyways. I've had to repair numerous cracks on my Accord with tig welds(rust problem, previous owner was a dick fuck) Finally gave up, chopped A lot of the shit out. If you have cross supports on the side though(they start from the corner and go 1/4th the way across your backseat, make sure you keep those...Remove them, you'll be dealing with A flexing kike.
Just built and installed a 6 cube box in my 2000 Camry today. Box is 40 wide, 13.25 tall and 24 deep outside. I cut alot of the plating out but i also welded in new plating. I can get pics tomorrow. I'm doing a sealed trunk build.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Also I would not out that box forward facing and against the seat in a Camry unless ur going to seal the trunk and rear deck of. Lost major output in mine like that sounded a lot better rear firing before I decided to do a sealed trunk build.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
