Help Asap! Fixed For Now!
already have..highest was 100 which i have in there now...but like i said once i order this will the cutting off stop? all other connections are tight as a virgin
Ordering a bigger fuse won't keep the amp from cutting off when it's at high vol. A fuse will cut the power all together when too much power is drawn through it. it's not like it's restricting power.
If the amp cuts out, it's because your not getting enough power through the wire. What size power wire are you running?
no thats the thing......it will cut off when it gets to hammering...no protection light or anything comes on......just cuts off...kinda like a warning to get the right fusing
Does just the amp shut off when hammering or is it the deck too?
just the amp...im using 4ga "what the amp imputs are"...and it cut off when i was driving and my electrical stayed at 14.4 when it cut off...so voltage isnt an issue
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
Your amp sounds like it's trying to suck a watermelon through a straw.
Or you have bad grounding
or the deck is cutting out.
Whats the fuse rating on the amp?
Whats the length of 4g wire?
120 on amp...reluctant to say but i put a 40 in the back when i first put in the amp....seems like i do stupid shit when im in a hurry...and the length is about 23 ft
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Well 4G is a little weak for any system these days. I would look into bigger wire.
Most likely it's a bad connection.
How is the amp grounded?
How is the battery grounded?
the amp is grounded good but i've had bad ground experience in the past....so im going to change it again and hope it works...if not im going to buy more wire and ground it from the batt up front....and the 4ga i have going to it is a very snug fit...so i doubt i would be able to fit anything bigger
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
  • Who's Online   1 Member, 0 Anonymous, 821 Guests (See full list)
