Difference between "2000" and 2000 watts
Guerra33
Crescendo is 2000 watts rms and the crunch is 2000 watt max
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
For a $100 amp, that crunch's board is very clean looking
That's a good example of cheap versus quality
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
plus the crunch is class a/b
i love this sh--t man 1966 Ford Fairlane Pioneer prs 80, the big three, with 2 big azz agm batts, dual 270/200 amp alts , two 8'' mids and tweets in the kick( PPI phantom 600.2). two 10''s and tweets in the doors, two 10'' mids and tweets in the rear decK ( Lanar opti 500x2). 2 C2 Audio Threatcon 4 12s on a Crunch GP3000d. No crossover .
2000 watt max is really something that you'll see for a pelt sec and also if it was struck by lighting so usually you see max the rms is half that but damn that crunch amp should do 1000rms clean that board looks good for a cheap amp.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
It´s 170 http://www.ebay.com/itm/Crunch-CR2000-1-2000-Watt-Max-Monoblock-Class-Ab-Car-Amplifier-/390656108050?pt=Car_Amplifiers&hash=item5af4eb2612
wrong amp the one he got is a P1-2000.1 not cr2000
here the one he got $101.95
http://www.vminnovations.com/Product_6134/Crunch-P1-2000-1-2000-Watt-Mono-Amplifier.html
2 sundown sd-2 d4
flex tech
box design by Joe X
Ya it wasn't too terrible, did the job when it was in need. Got pretty hot though.
Would i recommend it or buy another? Not likely
