Nice!! I didn't kno that any of rockfords amps would do .5
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Find him on Facebook. I dont feel like taking the pictures and saving them all to my photobucket.
Oh and I am pretty sure that the only thing used to power the amp other than itself, was a single battery.
they don't. This is a 4 channel amp with ALL 4 channels hooked up at the same time and in mono. It is actually a 1ohm load the way it is hooked up. Tony can expain a little bit better why that is. I didn't even know it was possible to do that. The only way i knew to do that was bridge front and rear channels and send them to the dyno as a 2 channel.
Again, Tony can explain how he did it.
Follow my Tweet (Twitter)
yup, one 12v battery.
and not to mention, those 15,000 watts are coming from one of the best SQ amps you can get. Sucks there is only 18 of them in existance. Sucks it hasn't trickled down to the smaller amps yet. Someday!
I am going to try and take a stab at this one, tony kind of explained it to me briefly about how to test a pair of big amps strapped.
The front and rear channel look to be bridged to 2 ohms each and then paralleled down to 1 ohm at the amp dyno. The dyno has its Ch1 and Ch2 inputs wired in series. The dyno run says .5 ohm, but since the inputs are wired in series, it is actually a 1 ohm test.
I may be completely off base, but that makes sense in my head. Hopefully Tony has a minute to come explain if I am just spouting off craziness.
15k off of one battery thats impressive
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
That is just sick on so many levels. I am surprised that the technology involved has net "evolved" into something else, on a smaller, more obtainable level.
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
  • Who's Online   0 Members, 0 Anonymous, 803 Guests (See full list)
