How many cubic feet (net) for my (2) Alpine SWR 1222D?
Syphlyn
So here is a suggestion, any changes let me know:
Port parts are:
Top to Bottom: 16 1/2" x 13 1/2"
Extension: 1 1/2" x 13 1/2"
Bracing: 1 1/4" wooden dowel rods.
I can go higher, but 34 is too big any way to reduce down to 32 or maybe 32.5?
Edit: The box is sitting between my back seat braces, so 32 or 32.5 would probably be a good width. Can you work with that? Also the 34hz tuning is fine :)
Also the width of the port is 4 inches all the way down but when you add the extension the width at the bottom of the port and around the bend is 5.5 inches does that change anything?
^ I mean to say is that the width at the bottom of the box goes from 4 inches to 5 1/2 inches.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
Updated to 32.5W, the port stays at 4" after the turn but you need to assemble exactly as the figure shows.
I see now forgot to add in the 1.5 from the MDF.
Thanks will this box be better than this one? Someone designed this one for me. In your opinion which one would be better? Difference is basically the tuning, net volume, and direction of port.
Sub: Sundown Zv4 12
bump
Sub: Sundown Zv4 12
You dont need a 1.5 inch thick box for 1k
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Your going to want to be around 4 cubes like joe said.
I ran a type r 12 on an audiopipe 3k at 2ohm ( 3k rated amp) daily and had no issues unless i felt like turning it wayyy up and bottoming the sub out. Let me tell you... Those subs can move lol... Box was also in the 2 cube area.. Ill fine te vid i took of it..
Personally i think Type Rs are an awsome "mainstream" entry level sub. Ive ran many of them.. Only one i have broken ( 1500rms free air Ripped tripple joint a few times.. Kept regluing)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Was talking about the .75 top and .75 bottom off the 22 bringing it to 20.5 - 16.5 (port length) leaving 4 inches width for the port "turn"
Sub: Sundown Zv4 12
Keep in mind Thats an ap3k ina honda civic.. Stock alt stock batt all i did was use a 2g power wire and 4g ground. Got 9v?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
It doesn't take much to move these subs. Build the box to specs not what people are telling you. If you blow these, they are a pain to recone and you will see that they use cheap parts and terminals, leads, exc. These were one of my favorite Chinese subs.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
  • Who's Online   0 Members, 0 Anonymous, 1626 Guests (See full list)
