Turning a sub box into home audio?
Ok, so once my Sound Cubed woofers get here, I am not longer going to need the 12 in my trunk. It is one of those pre-made, built in amp inside the box 12" Planet Bass thing-a-ma-jigs. So, if I don't throw it into my girlfriends Yukon, I may try to use it in my house. My question is, how do I wire it up? Can I splice the power wire into a regular indoor wire with the wall socket? Would it have to be fused somehow? And what about the remote, and RCA's? Do they just go to the back of my flat screen, or do I need some kind of receiver? Any links or wiring from car audio to house audio would be great.. Don't wanna burn the house down.
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
You need a power inverter, right now it is set up for 12V DC and a wall socket is 110V AC.
The problem with running car amplifiers indoors, is that car amps are made to run off of 13-14 volts DC, whereas the wall sockets in your house put out 120 volts AC. So it would toast the amp if you just tried plugging it into the wall. One method people use to run car amps indoors is to make a bank of computer power supplies and mod them to put out 13-14 volts DC instead of the typical 12 volts.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
You will need a 120VAC 60 hz to 12VDC converter.
Something like this, all though I am not sure how well these do under load for long periods of time.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=120-558
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
That supply only puts out at most 40 amps continuous.
And what KMS said is best, just get an amp made for in house use.
Actually a cheap power supply is a 12V car Battery constantly hooked up to a battery charger. Just turn on the charger every time you have the amp on.
Also, yes you would need some sort of receiver. And the remote turn on can be turn on from a switch.
It's more than likely just not worth the effort especially if you don't really know what you are doing.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Oh wow, thanks guys.. But I think I will just put it in my girls car and get one of those sound bars for the house. She won't mind ;)
If you knew electronics for houses you can get a buck down transformer converter. Cheaper to purchase a crown pa amp!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
