jrath Posted September 25, 2013 Report Posted September 25, 2013 I have one battery under the hood and another battery in the trunk. They are connected only from positive-to-positive with 0 gauge wire. I have a battery charger and would like to charge the trunk battery only. If I connect the battery charger to the trunk battery will this affect/charge the battery under the hood in any way? I do not want to send additional charge to the battery under the hood if it doesn't need it. I fear explosions. I am hoping I can simply charge the trunk battery without disconnecting the + wire between the two batteries. Also, do I need to disconnect the + wire from my trunk battery to my amp?
cloud77 Posted September 25, 2013 Report Posted September 25, 2013 Yes, you really should disconnect all wires when charging. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
tacomaguy1 Posted September 25, 2013 Report Posted September 25, 2013 Just leave everything how it is/connected Wont harm the front battery by charging it also, if anything it will help it Why do you "fear explosions"? What kind of charger is it? Team Flex Issues
Facekicker Posted September 25, 2013 Report Posted September 25, 2013 Providing everything is in good condition, you won't harm the front battery unless you're using a charger that doesn't have a circuit. 2002 Monte Carlo Started a build log Fi, DC, Mechman, XS Power
SnowDrifter Posted September 25, 2013 Report Posted September 25, 2013 Just unhook the ground for your trunk battery. Hook the charger to the battery itself. And you are good to go But my question is why do you want to charge only your trunk battery? Why not all of them? I'd be more concerned for an explosion in the trunk than under the hood. Gases ate trapped. Which brings up a different point- - a proper charger won't cause your batteries to gas excessively, so this isn't an issue you should need to worry about. Once again, provided you have a good charger. If not, then you shouldn't be using it in the first place ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
jrath Posted September 25, 2013 Author Report Posted September 25, 2013 Thanks for all the fast responses. You guys are great. I have a CTEK 3300 battery charger. I would not mind charging both batteries, as long as extra wiring is not required. Would both batteries charge if the negative poles on the batteries are not directly connected? I know they are connected indirectly via ground. The CTEK battery charger has a sensor to avoid overcharging. However, I feared that if my front battery is holding more charge than my trunk battery than the charger may somehow detect the nearly full front battery and not fully charge the trunk battery.
Wicks Posted September 25, 2013 Report Posted September 25, 2013 You could run into more issues if you only charge one battery and then interconnect it back into yours car's electrical system repeatedly. You'd be connecting a resting battery with a freshly charged battery. That may only be a difference of ~0.5V but at a battery's capacity that's a lot. Plus you'd be charging the under-hood battery in this scenario anyway when you reconnect the trunk battery. Go ahead and charge everything connected and it will be just fine. In your car ALL the negatives are tied together. ALL the positives are tied together. Doesn't matter if you are using straight wire or the chassis. Its all the same. My only concern would be to avoid putting a lead-acid battery in the trunk since they are prone to leak gas which could flow into your cabin. Make sure its a sealed battery and you're all good. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
jrath Posted September 25, 2013 Author Report Posted September 25, 2013 Thank you Wicks. The batteries are Kinetik HC1400's. I will just leave everything connected as is and charge both batteries simultaneously.
cloud77 Posted September 26, 2013 Report Posted September 26, 2013 That charger recognizes battery type, (agm,lead acid), amp hour capacity, and health of the battery upon placing it on the terminals. It charges at only about 4 amps, but is called an intelli charger for a reason. It recognizes the state of the battery its connected to and provides maintenance accordingly. If your positive lead is still connected to the front battery it will not recognize the specs of the battery you intend to charge. Opposite polarities attract, and your front battery is grounded. Most of the trickle charge of 4 amps will be lost in the relay of your positive lead to the front battery. You will find that you will have the charger on the battery for hours and hours and the light never goes 100% because of this. So...Just disconnect everything and you will get a correct charge. 2004 Grand Prix GT (2) 12" RE XXXs (04/05 XBL^2) 5 cu. ft tuned @ 35 Hz MMATS HD4000.05 MMATS SQ4100 Infinity Kappa components Juice Box black cherry Duralast platinum group 34 1/0 KNU OFC, 2/0 welding Singer 250A
mikeg321 Posted September 26, 2013 Report Posted September 26, 2013 That charger recognizes battery type, (agm,lead acid), amp hour capacity, and health of the battery upon placing it on the terminals. It charges at only about 4 amps, but is called an intelli charger for a reason. It recognizes the state of the battery its connected to and provides maintenance accordingly. If your positive lead is still connected to the front battery it will not recognize the specs of the battery you intend to charge. Opposite polarities attract, and your front battery is grounded. Most of the trickle charge of 4 amps will be lost in the relay of your positive lead to the front battery. You will find that you will have the charger on the battery for hours and hours and the light never goes 100% because of this. So...Just disconnect everything and you will get a correct charge. 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
