So I heard from a member of another forum I'm a part of (to remain unnamed) that while still in the "breaking in" phase of a new subwoofer that the more low notes you play the lower the sub can play on full tilt. An vise versa with high notes. I feel like he is full of shit, so I figured I would ask, any truth to this?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
i don't think that's right....it just doesnt seem right...i mean the box would be the factor on how it plays, and how it breaks in. but i could be wrong, cause i dont know, but it could work i guess...
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
Id live to see his.logic behind this
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
As the suspension loosens up the parameters of the driver will change very slightly.
The main point of the "break-in" myth is that it effects how much power you can send to it. Some Manufacturers try to get their customers to follow this method as a way of protecting the company.
That way if a driver is blown within the stated "break-in" period the seller can just ask how much power was being sent to it. After they get an answer that is at the RMS of the driver they can just say it was your fault that the driver blew.
When in reality if you are sending the driver a clean signal at rated power it should be fine, as long as the rated power is the truth and not doctored numbers.
So to wrap it up, yes a sub can play lower, ever so slightly, after a period of time when its suspension loosens. But a "break-in" period is a myth.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
I don't see how it will help high notes.
I had two sa-12 i used for almost a year, wanged them almost every day. Bought two more, the suspension felt exactly the same. If "break in' was true, why would sundown tell me mixing old and new subs would be perfectly fine?
ive noticed with everything the same that i could get my subs sticky pretty easy if i started getting on them but now that ive been using them for about a month i cant not even if i tried so once the suspenstion loosens up that must help a bunch in cooling
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
haha id have to call bullshit on that one
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
  • Who's Online   0 Members, 0 Anonymous, 752 Guests (See full list)
