coil rub on recone
ncc74656
now i was always told that kickers are solid amps and that has been my experience as well. thats why i went with them over a crachendo or pioneer. also the 3KW amp paired with a 3KW sub sounded like a good combo.
i want to know how much of hte amps potential it is using with bass boost and gains down vs gains up and boost down vs boost and gains up. i want to make a graph of this for 25-90hz in 5hz increments.
just getting things to work is not good enough i need to understand why they are working now, why they were not working before, and what i did wrong in the processes.
nothing, gutted
ZX2500.1 from his sig
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
ok.
RCA's have 0.7V AC
kicker amp sits at 1.1v at rest with gains/bass boost down. turning up gains will move this to 1.6 and bass boost will bring it to 2.7V
while playing the amp peaks at 51V ac at 33.4hz
my eclipse amp shows 13.3V on one channel and 11.1V on the other at max volume
max voltage drop at amps with engine off is .8V and nominal is .34V
subs best volume by ear is with gains 3/4 up and bass boost 3/8th up
by my math the most this amp puts out is 1300W in its current setup.
nothing, gutted
Did you take in effect phase angle?
You need to set the gain based on the voltage of the head unit not by ear, bass boost should only be above 0 if you are measuring at the one note it boosts or else it can cause a distorted signal at and near that frequency.
as far as shims..... you can basically use whatever you want, my preference is higher quality printer paper.
Get the circumference of you coil, 4in coil would be 4*pi or ~ 12.5in, and get a few layers of paper 6in wide or so, and the circumference long, and use a seamless shim all the way around with the paper almost touching, but not over lapping. This will insure a perfectly aligned coil from top to bottom using the inner coil and pole piece. then lay the spider landing glue. I like to wait between surround and spider landing glue-ings because if the spider landing isnt setting yet, when you manipulate the surround and glue it you might tilt the recone ever so slightly, even with a tight shim, and cause coil rub in the ends of excursion.
ok.
RCA's have 0.7V AC
yea... the thing i put in red.... turn it off. Just because it makes it sound louder doesnt mean it is good for the amp. It has a purpose, and you are not using it correctly.
i used a 45hz test tone for these numbers or a 25-90hz sweep
i do not get proper volume out of this sub with out bass boost up. i dont know if i need a line driver, a new deck, a differnt amp or sub... but there is no way this amp is powering this sub properly.
i just removed my group loop isolators on the RCA's for the mid/high amps to see what that does.
my sub RCA's are at 4.1V but my mids/highs are at 0.7
how do i get this sub to move with out bass boost? one post im told never to use bass boost, next post im told that its fine so long as its not done to much and to tune by ear, next post im told to turn it back down... im getting pissed off here
nothing, gutted
how do i get this sub to move with out bass boost? one post im told never to use bass boost, next post I'm told that its fine so long as its not done to much and to tune by ear, next post im told to turn it back down... im getting pissed off here
Disregard that.
  • Who's Online   0 Members, 0 Anonymous, 6425 Guests (See full list)
