SMZ2 Posted October 10, 2013 Report Share Posted October 10, 2013 Well as some of you know I've been working on my door panels and pillars. It was 80 degrees last week now it's 60 degree can I glass at this temperature? I know I can add more mekp but won't that make it more brittle? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713 Link to comment Share on other sites More sharing options...
HHR Ed Posted October 10, 2013 Report Share Posted October 10, 2013 It'll be fine. You are still withing the temperature range that is OK for resin. You can always look at the manufacturer's specs on the actual resin you have but usually its OK until you get down to freezing. You just have to adjust your mixture accordingly. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
SMZ2 Posted December 7, 2013 Author Report Share Posted December 7, 2013 So even with it being in the 40s today I can still glass? I laid out some kitty hair last night but I did not expect it to be 46 degrees today. I am using the sticked chart for MEKP in this section of the forum. I guess if I mix 1.75% I will be good. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713 Link to comment Share on other sites More sharing options...
purplesyrup Posted December 7, 2013 Report Share Posted December 7, 2013 If your still going for it in that cold of a temp I'd suggest having some heat lamps on your project. Link to comment Share on other sites More sharing options...
ric006 Posted December 7, 2013 Report Share Posted December 7, 2013 Torpedo Heater MAN u will love it forever Link to comment Share on other sites More sharing options...
SMZ2 Posted December 7, 2013 Author Report Share Posted December 7, 2013 If your still going for it in that cold of a temp I'd suggest having some heat lamps on your project. I may just wait till it gets up to 50. Apparently it is supposed to. I don't have a heat lamp though so yeah. I may just have to play the wait on warm weather game again. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713 Link to comment Share on other sites More sharing options...
SMZ2 Posted December 7, 2013 Author Report Share Posted December 7, 2013 Torpedo Heater MAN u will love it forever My problem is that I usually work outside. There isn't much space in our storage shed that I keep my stuff in. If I used a heater would I mix the resin at a lower % of MEKP though? I may be able to get my hands one though if it would help. My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713 Link to comment Share on other sites More sharing options...
raolito1980 Posted December 7, 2013 Report Share Posted December 7, 2013 I used the 3M glass and it took forever to dry using a heat gun or whatever. I ended up using way more hardener and still didn't help. 2012 GMC SIerra CC System Build Headunit--Stock Sub Amp--DC 2.0k Subs--2-SA8v2's Enclosure--Need one made!! Highs Amp--Sundown SAX-100.4 Front Highs--Rockford Fosgate T2652-S Rear--Sundown Neo Pro 6.5 XS Power D2400--XS D3400 No Big Three yet! http://www.youtube.c...ser/raolito1980 Link to comment Share on other sites More sharing options...
SMZ2 Posted December 7, 2013 Author Report Share Posted December 7, 2013 I used the 3M glass and it took forever to dry using a heat gun or whatever. I ended up using way more hardener and still didn't help. Great that is what I am using.... Did you follow the MEKP chart on the forum or just 40 drops like it says on the container? Also what was the temperature? My Build Log!http://www.stevemead...nissan-xterror/ Check the Youtube Channel for Updates!http://www.youtube....ser/Xterror2002And Seller Feedbackhttp://www.stevemeadedesigns.com/board/topic/163179-bought-from-smz2/#entry2363713 Link to comment Share on other sites More sharing options...
THEKINGsBACK Posted December 7, 2013 Report Share Posted December 7, 2013 Get some sun flash he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick: Link to comment Share on other sites More sharing options...
