Mr Arkansas Posted October 17, 2013 Report Posted October 17, 2013 I would have to say its more likely cause of the way the sub is wired 93 Honda Prelude H22a 2 Deka g31s, Sealed off trunk, 50ft of deadner 3 cans of great stuff Big 3 in Stinger 1/0 gage 4 6x8s polk audio and 4 orion tweeters Mtx Ta3202 on 2 dd 6.5s Phd3 Sundown x 12.2 in a slambox tuned to 34hz at 1ohm<p>
CleanSierra Posted October 17, 2013 Report Posted October 17, 2013 I would have to say its more likely cause of the way the sub is wired ....or that it was run for 40 minutes with the vehicle off? Im not the one you want to try to troll. Just a fyi for you.
ncc74656 Posted October 17, 2013 Author Report Posted October 17, 2013 sub is wired with 8ga in series from dual 1 to a 2ohm load. (dual 0.7 to 1.84). im not sure how i could do anything with wiring to change this. also there are no terminals on the box. nothing, gutted
justin0943 Posted October 17, 2013 Report Posted October 17, 2013 so my parts list will be a 150ohm 5% resistor and 2 RIF3205 mosfets with date code 924P yes your right don't for get the resistor is 1/4 watt from what I see here, the date code 2009 week 24 line p and you'll be good to go.also I just check out the irf website they have an upgrade mosfet to replace the old one so you can get a little more power out of that amp it'll be IRFB3306PBF as an upgrade. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
ghostlyrich Posted October 17, 2013 Report Posted October 17, 2013 i would call up kicker and let them know the situation 2 times in 4 months might get you a new amp and that way you don't fix this problem and then somthing else goes wrong My youtube channel https://www.youtube.com/user/ghostlyrich Mazda 3 2006 Build (R.I.P) http://www.stevemeadedesigns.com/board/topic/172728-mazda-3-2006-stealth-build/ Volkswagen GTI 2011 Build http://www.stevemeadedesigns.com/board/topic/192979-vw-gti-2011-build/ Jeep 2015 Build http://www.stevemeadedesigns.com/board/topic/201493-my-new-jeep-2015/
biscuitownz Posted October 18, 2013 Report Posted October 18, 2013 From experience, the success rate with replacing MOSFETs aren't that high. Usually once you put the new ones in, and you go to turn it on something else pops...
Soccerballzs Posted October 18, 2013 Report Posted October 18, 2013 When this happened to a amp of mine I replaced all mosfets. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Guest Posted October 18, 2013 Report Posted October 18, 2013 From experience, the success rate with replacing MOSFETs aren't that high. Usually once you put the new ones in, and you go to turn it on something else pops... this. this. this. then the repair bill will likely be even higher.
ncc74656 Posted October 18, 2013 Author Report Posted October 18, 2013 well ill find out. i just bought 3 mosfets and a 100 pack of resistors this morning. ill give it a go and see what happens, worst case i spent another 2 days and 10 bucks on 20 mosfets. nothing, gutted
CHEVY4X4BLAZER Posted October 18, 2013 Report Posted October 18, 2013 Send that amp back if you're still within your 90 repair warranty. Shipping costs are a lot lower than the out of warranty repair costs.
