I need some electrical help.
Okay, heres a list of my gear, and my issues.
260A mechman alt,
1 run of 1/0,
3 grounds in 1/0 - Chassis, frame, engine
1/0 run from alt to positive batt
Brand new deka intimidator deep cycle up front,
two brand new 91 ah batts in back.
batts in back grounded to chassis. all grounds are perfect.
all connections are soldered.
On cold start, everything charges at 14.2.
after it warms up, rear batts sit charging at 13.6-13.8, front alt and batt still at 14.1.
what could posssssibly be the issue. Im stumped.
oh and car off, everthing sits at 13.1.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
The cable run you lose resistance it is normal. You are good.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Vehicle?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Is with with or without a load? With a load it's normal. But without one, it's not
Sorry I'm on mobile but N8, it's a 2000 s-10 with a 4.3.
And snow, that's just with no load really, just my stereo, my 4 chan and EQ on.
Alt - Singer 330A
it should be charging at 14.1 everywhere.
no, there is ALWAYS voltage drop across cables.
with no load, charging 14.1 up front, 13.9 and up is ok. Anything lower and you might have some dirty grounds, or something of the sort causing voltage loss. Could be long cables as well.
.6v front to back drop with no load is NOT normal. You shouldn't even have .1v drop in this scenario to be honest
Op, do you have a multi meter? How are you measuring your voltages?
Yeah, I'm measuring voltage with dmm. At alt, front bat and both rear bats
Alt - Singer 330A
Start working your way down the wire. Pre fuse, post fuse, midpoint of the wire - you can poke the probes through the insulation. Measure at your rear batts, but instead of putting the negative probe to the negative post on the batteries, put it to the chassis or some other ground
  • Who's Online   2 Members, 0 Anonymous, 1312 Guests (See full list)
