150 db or close out the trunk
Jskiles
The one guy with the Mazda with the JL w7's and 2 1000hd's did a 151 out of the trunk and change ports yielded I think a 147 at 17hz?
I hope to be on the 150 trunk list one day.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Brian Nyman of Team Bassick. Look him up.
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
Thanks for the replies. I doubt ill be able to fit 2 15s in a forte koup, but 12s would be possible. As for power I was thinking about starting out at 2 cresendo bc2000s and 2 2k watt 12s firing forward seals off with as many batteries I can fit. One of my problems is finding an alt for this car.
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
I've done 144 out of the trunk (without fold down seats) on 2500watts and 2 10's.
with the new build plan, I should be able to get 150's and without folding seats down or doing rear deck blowthru.
actually, cone don't play here....
Thor, and the like, use 12's... jus sayin
Hopefully I'll be 147+ with my 2 12s :nuts:
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
No offence. Your a good 8 db away, (not just math)
Good luck. Not all do it, because most cant.
Trunk,.. around.. AROUND a 50 (he didn't wanna lean on it)
http://youtu.be/32U9WGk9XrU
Wish you the best,. but, its harder than what you think..
If your doing a TRUE trunk build.....
Right now I'm 150db away lol
But with the new amp and trunk build I'm 90% sure I can hit it.
144 was done before sealing off the rear panel, using improper box and stock electrical. (ran sundown saz2500 on D3100 and stock alternator. Voltage dropped to mid 10's).
And that was pretty damn impressive score to be honest.
My definition of a TRUE trunk car is : A car that has all equipment in the trunk and the port of the box is either fired towards the sides, top, or back of trunk, seats can be folded down or kept up.
If you are sealed off fired forward, you are just utilizing the trunk for your equipment and are not actually having any pressure come from inside the trunk.
With that being said i am in no way talking crap about peoples builds that are using the trunk i think they are great, and i myself will be sealing off firing foward here in the near future.
My best score to date is a 145.5 @ 29hz port fired towards the side, not sealed off. I have acheived a 146.1 but that was on a test run.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
  • Who's Online   0 Members, 0 Anonymous, 3085 Guests (See full list)
