Tips for Building box for Hair Tricks
Hi-Po 5.0
I will have to try that math thing out when i get off work. Thanks man. Really appreciate it!
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
If I post up my current box specs can somebody tell me if it will do hairtricks? I know it is moving alot of air but I need biggers amps and custom 12s :-)
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I used a 10 step program to build my wall. It is really simple.
1. Gut car.
2. measure, measure, measure, measure, measure. measure, measure, measure.
3. plug "net" numbers and various ports into torress.
4. Use sketchup to plan and design within my measurements
5. measure again
6. repeat steps 3 and 4.
7. Purchase wood and begin building.
8. finish and find out i still did something wrong and box is about 1cuft bigger than i though it was and port area is probably too much.
9. curl up in fetal position and cry myself to sleep.
10. Redo it again next summer with more power and more cone area.
1. Gut car.
5. measure again
I am for sure going to try this
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
I was going to just build the box to what i can fit comftorably (behind rear seats, need room for amp rack behind wall). then plug those dimensions into torres, and go from there, considering my port will be a 0 common wall it will be really easy to adjust its length, just wast to sure on how much port area i needed.
93' Exploder
1. Gut car.
5. measure again
Best be prepared to follow steps 7 through 10 quite a few times lol
10501650_10203332501847103_1859383749711
Blown
Ok bud.... ok...
Me? ALL about the power your gonna run....(real power, with elec) Then, build your box.
Pray subs are willing to take it...
edit - swappin drivers is easier than swapping elec, and amps, and wire and that shit. (to me)
May, or may not produce a trick.
Especially if you want it musical. Like, broad musical. Where I got dicked a bit.
Most here, make more wind than I, then again, I can play NIN, or some Greatful DEAD to make me and the wife smile.
SOOOOOOOOOOOOooooooooooooooooooooo...
do your best, and we are here to help, BUT,.. most of it? will come down to trial, error, test, tweak, and bumming off those that have "dun it".
Wish you the best. I didn't mean to poke fun about your question, or your thread.
cheers...
  • Who's Online   0 Members, 0 Anonymous, 1690 Guests (See full list)
